Old 10-02-2016, 09:08 PM   #1
Jonathan91
Jonathan91 is on a distinguished road
Default Headgasket questions
First of all i dont own a supra but a cressida. I figured this forum would know more about 7m's than some of the other toyota forums.
Anyways my question is im replacing a headgasket on my cressida but dont know what headgasket thickness i should get or brand. I think the metal headgasket is an overkill for the 7mge and i dont want to machine the block. I will machine the head though. So which headgasket brand and thickness should i get? Also should i get just the arp studs or the bolts too?
Jonathan91 is offline   Reply With Quote
Old 10-08-2016, 04:20 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
When I did the head gasket on my 7MGTE, I used OEM Toyota head gasket, bolts, and washers. No machine work was done, all I did was clean the surfaces very well and torqued the head bolts in 3 passes to 75 ft/lbs. Car is not stock (bigger turbo, exhaust, etc) and I've had 0 head gasket issues since.
What I'm saying is that I think you'll be fine with OEM parts, as long as you clean the surfaces well, torque the bolts in the proper sequence, and to a more suitable torque spec
Replacing the headgasket burton51m Show n Tell 4 07-12-2010 04:47 AM
Headgasket questions ReelBandit MKIII Supra 4 06-07-2010 05:44 AM
89 Turbo 5sp blown headgasket for sale Ms89Turbo5sp Buy/Sell Cars 1 03-26-2010 10:09 PM
HeadGasket Questions scaggsj MKIII Supra 10 08-11-2009 03:37 AM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
