Old 10-17-2005, 11:22 PM   #1
boner1115
boner1115 is on a distinguished road
Default my car is messed up please help me
ok so 1 of my screws ont eh differential was sheered off and one screw that si connected to i think it is called the cross member striat ripped off a chunk fo the cross member, i dotn knwo what to do?
boner1115 is offline   Reply With Quote
Old 10-18-2005, 02:25 PM   #2
Bullz_EyE
Bullz_EyE's Avatar
Translation:
OK, so one of my screws on the differential was sheared off. Another screw that is connected to,what I think is called the "crossmember", ripped off a chunk of the crossmember. I don't know what to do?
Can you take pictures dude? Your description is horrible. :P
EDIT: If you reffer to bolts as "screws", which they are but, are always reffered to as bolts, I think you shouldn't be working on your car and it's best to take it to a mechanic. No hard feelings.
Old 10-20-2005, 01:20 AM   #3
Burn N' Up
Burn N' Up's Avatar
I'm thinking you should listen to bullz eye about working on your car. No offense. What you should do is take it to a shop.
Old 10-20-2005, 09:30 AM   #4
sounds like you need an engineering shop to tap new threads and to repair your rear crossmember
good luck
Old 10-21-2005, 01:14 AM   #5
rnoswal
rnoswal's Avatar
Is the car driveable any? If so, take it to a shop like ^ mentioned, if not tow it, but get a professional to look at it.
Keep us inflormed.
Russ
Old 11-06-2005, 09:08 AM   #6
boner1115
it is fixed and it only took 16 hours, and less then 200 dollars ill post pix soon you wont belive how bad my cross memebr was.
messed up problem supradeebs MKIII Supra 2 05-08-2008 05:04 AM
