Old 03-19-2017, 10:52 PM   #1
mirage83
Default Wiring connector questions, pre-89 and 89+ transmisisons
Got a question I'm having difficulty finding an answer to. Are there any differences in the wiring connections between pre-89 and 89+ automatic transmissions? I've got an '88 and have a transmission out of an '89 available if all the connection will plug up right. Thanks in advance for any information on this.
Old 03-28-2017, 03:17 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
As far as I know, the transmission wire connections are the same (as long as you're sticking with the same transmission; a340e, w58, r154). I can't say that with 100% certainty, but I can't say I've come across any transmissions that didn't connect to the wiring harness correctly.
Old 03-28-2017, 11:59 PM   #3
mirage83
Excellent. I much appreciate that information, as I've been waiting to swap transmissions until I had at least some confidence that the wiring connections are the same on both. Thanks for chiming in.
Old 05-10-2017, 12:58 AM   #4
mirage83
Just wanted to follow up with you on this, as there is indeed no wiring difference that I could find. Plugs right in. Now, the extension housing (tailshaft housing) is different as the speedometer plug is on the opposite sides of the housing, and the shift rod is different, but wiring is the same.
Converting Engine Wiring Harnesses between Yellow and Gray Plugs btwilson86 MKIII Supra 3 09-12-2013 11:26 PM
1985 wiring help bigtoyz MKII Supra 2 01-27-2012 04:22 AM
Engine wiring loom? redsupra MKIV Supra 4 12-19-2011 01:05 AM
Power Folding Mirror Install nfa_automotive MKIII Supra 2 05-25-2010 01:13 AM
HKS VPC wiring diagrams cat007 MKIII Supra 0 11-07-2005 09:28 AM
