Old 03-05-2018, 12:39 PM   #1
yale
yale is on a distinguished road
Default Wiring bundle question
After swapping out my 7MGE with another one I have two electric connectors that remain unidentified. The engine swap was short block so all the harnesses and components were reused. It is an automatic.
The first is a bundle of five (5) brown and brown/white that are all part of single loop. Very much like a ground connection. These come down through the intake plenum and reach down towards the starter area. I believe they are ground and connect with a bolt on the plenum.
The second is an electrical connector, square and grey/clear, that appears to go with the three large transmission connectors, again down by the starter.
The starter will not engage but I believe that we have one of two issues there. 1) neutral safety switch or 2) security system (but I don't have the Theft Deterrent Computer in the car anymore).
Any help on identifying those electrical connections would be appreciated.
yale is offline   Reply With Quote
Old 03-06-2018, 05:03 AM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Yes there is a bundle of ground connectors that bolt on to the intake manifold where the 2 manifold pieces meet. On my 87 Turbo with a manual transmission there are 2 copper pieces that the wires go into like a clip that bolts onto the intake manifold. One time I forgot to tighten that bolt and it acted very squirrely, dying randomly, etc. About the automatic Wiring, I cannot say, since I've never had one. You may be able to find something online at cygusx1 or in the back of a Toyota dealer shop manual for your year.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
Old 03-06-2018, 12:12 PM   #3
yale
Thanks for the reply!
We tested those wires several times and found they were not hot so went ahead with grounding them on the plenum. All is well.
Car is running and shifting fine without that 4-wire block being connected. It was extremely dirty so probably not in use to begin with.
Tags
wiring harness
7mgte Wiring harness question supraheelfan MKIII Supra 16 06-11-2012 10:26 PM
I'm starting to buy parts for my 1jzgte swap... wiring question? cfurlan MKIII Supra 0 01-12-2011 01:09 AM
1989 non-turbo wiring harness question Oceanside MKIII Supra 0 10-23-2010 09:37 PM
question about wiring harness????? tone loc MKIII Supra 2 08-30-2006 09:20 PM
Wiring question? redmaro MKIII Supra 4 05-12-2006 04:34 PM
