Old 04-21-2018, 02:04 PM   #1
Deaner1964
Deaner1964 is on a distinguished road
Default Info on fuel lines
Really quick just need your feed back on the proper size fuel line , I’m deciding on what size an fittings and hose , standard info, 1990 mk3 2jzgte swap , 272cams with a turbonetics hurricane series 7866 haven’t got around to fuel system yet , I don’t have injectors or fuel rail nor pump or lines , any feed back would be great
Deaner1964 is offline   Reply With Quote
Old 04-27-2018, 04:40 AM   #2
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
What WHP are you planing on making? Also do you plan on running E85 as that makes a difference also?
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Can I just buy a fuel pump filter? leftfoot MKIII Supra 8 08-11-2015 05:09 AM
1987 Toyota supra fuel lines wstanek MKIII Supra 2 05-15-2010 12:26 PM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel pump info Please! rlipp69 Non-Generation Specific Questions 3 05-24-2007 04:36 AM
