#1 |
Really quick just need your feed back on the proper size fuel line , I’m deciding on what size an fittings and hose , standard info, 1990 mk3 2jzgte swap , 272cams with a turbonetics hurricane series 7866 haven’t got around to fuel system yet , I don’t have injectors or fuel rail nor pump or lines , any feed back would be great
#2 |
What WHP are you planing on making? Also do you plan on running E85 as that makes a difference also?
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior. |
Can I just buy a fuel pump filter? | leftfoot | MKIII Supra | 8 | 08-11-2015 05:09 AM |
1987 Toyota supra fuel lines | wstanek | MKIII Supra | 2 | 05-15-2010 12:26 PM |
Fuel pump relay and pressure. | carfanatic89 | MKIII Supra | 8 | 05-01-2008 06:39 PM |
Testing for bad ECU, &/or bad Fuel Pump | elliotl | MKIII Supra | 0 | 08-21-2007 10:42 PM |
Fuel pump info Please! | rlipp69 | Non-Generation Specific Questions | 3 | 05-24-2007 04:36 AM |
