Old 12-24-2004, 01:40 AM   #1
frobro420
frobro420 is on a distinguished road
this morning there was a pool of oily substance(possibly power steering fluid) under my car, later after work i notice a pool of coolant, whats going on??
frobro420 is offline   Reply With Quote
Old 12-26-2004, 04:05 PM   #2
GOGS
GOGS is on a distinguished road
HI
Check levels of pas fluid ,coolant +auto box if fitted .If all ok run+check for drips from the motor + identify which area ?Paper will show what colour when it lands+what area.
GOGS is offline   Reply With Quote
Old 12-26-2004, 10:31 PM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
when was the last time you had your car serviced?
maybe it's in need of new waterpump, radiator cap & thermostat, probly most likely you need a new radiator cap... is the pool of coolant coming from the area where the water bottle is at the front of the car or a different place, check all your hoses for splits etc
looking for old rusty water sitting on your motor will help you to find leaks as well
most likely your fluid that's on the ground will be ps fluid, the hoses going to the reservoir have probly just finally aged
another place that loves making supra owners replace them is the suages (fittings) in the main power steering line that bolts to the side of the strut tower, you can develop a leak there
have a look around your engine and see what you can find or at least what area it's coming from and what colour it is
good luck
Pics of my build.
Do a diagnostic first!
Old 11-08-2005, 10:22 PM   #4
Isphius
Isphius's Avatar
I have a similar problem....my 88 is leaking radiator juice from the back of the motor somewhere, and dripping on/around the exhaust manifold. i thought it was a broken heater core or hoses...all replaced, and i blocked off the heater core but its still leaking. and its not the head gasket....so i dont know where else it could be coming from? anyone else that has a similar problem? please help
Locating Boost Leaks slader99 MKIII Supra 5 05-21-2008 01:12 AM
Oil leak(s) mattapo MKII Supra 3 12-21-2006 08:20 AM
Targa top leaks!!!! 90' turbo supra brandonsupra MKIII Supra 0 10-23-2006 08:04 PM
Targa driver side leaks when it rains!! Ahmad88 Exterior , Interior, and Detailing 5 07-21-2006 02:49 AM
Oil leaks on turbo Sath Non-Generation Specific Questions 0 12-04-2005 05:48 PM
