Old 06-30-2018, 01:40 PM   #1
Life is Supra
Life is Supra is on a distinguished road
Default Boostcontroler problem
Hi, can u help I buy cheap boostcontroler from ebay, try to put ot but the arow on pic was point at other way(find out later). Try and reverse those two lines from turbine to wastgate.And now the blow off valve dont work and all and the wush sound comes from turbo inlet insted of blow off. Remove the boostcontroler and its all the same.And boost is now weak the car wont accelarate like before this stupid controler.Only get 51 code but that code was there before and car was boosting normaly just before this instalation,now there is no power. And for the record I installed the aftermarket fuel pressure regulator.Maybe its some problem with turbine dont know,please help.I will take a picture of my build tomorow if that helps
Life is Supra is offline   Reply With Quote
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
