Old 10-19-2005, 03:34 PM   #1
SupraMan1784
SP58GT
i used the arp bolts for my head when i used to own the 7m...i dint have it for long so im not sure...i ahve teh bolts on my 1jz right now and theyre pretty good...apparently studs seems to be popular for the 7m...
Now: Saving for an MKIV
Broken Rides:
Old 10-20-2005, 09:39 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
studs are where it's at
Pics of my build.
Do a diagnostic first!
Old 10-21-2005, 01:11 AM   #3
rnoswal
rnoswal's Avatar
Sigh.................^........... , .
Russ
Old 10-26-2005, 02:51 AM   #4
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
The price difference between the two is insignificant, with the studs being only $10-$15 more. As far as installation goes, how do they differ? Are there special tools required to install studs? What are the main differences between the two (other than torque settings)?
I'm leaning more towards bolts, because I'm thinking they're gonna be easier to install.
Bullz_EyE is offline   Reply With Quote
Old 10-26-2005, 12:40 PM   #5
SupraMan1784
SP58GT
bolts are easier to install...but honestly...since i have installed both, id say studs are teh way to go since they would be a little more reliable...but it really doesnt matter...if you do it right...the installation that is...everything should come out ok...hopefully
Broken Rides:
Old 10-26-2005, 01:49 PM   #6
rnoswal
rnoswal's Avatar
If you are looking for every last bit of horse power, then go with the studs. They won't distort the cylinder walls when you torque the head like the bolts will. Granted it is a small difference but the bolts do stress the threads in the block and will cause them to open just a bit so the cylinder walls distort at each bolt hole in the block. This causes the rings to not seal as well and so a loss of horse power, however small, but a loss just the same.
It would be best to have a friend help with removal and installation with head on the studs, but it would be worth it. It's kinda like Suppra-girl said earlier. And it would be a long time before you blew that head gasket too.
Russ
Head studs on fresh motor? mnemonic345 MKIII Supra 0 03-02-2009 01:10 PM
ARP head bolts or studs? mirage83 Non-Generation Specific Questions 0 03-19-2008 10:09 PM
head gasket bolts marc MKIII Supra 6 10-23-2006 07:23 PM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
ARP head bolts Deputy99 MKIII Supra 2 07-19-2006 11:16 PM
