Old 10-12-2018, 03:00 PM   #1
TClark
TClark is on a distinguished road
Default Vacuum Port by EGR Tube
Question. What plugs into the Vacuum Port in the rear of the Intake Manifold by the EGR tube connection on a 1990 Supra N/A? I don't see anything unplugged.
Thanx from 10EC.
TClark is offline   Reply With Quote
Old 10-19-2018, 07:46 PM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
A photo would help. There should be a vacuum diagram underneath the hood of the car. The only thing that sounds related is are you talking about the power steering booster hose? You can consult the online Supra manual. http://www.cygnusx1.net/Supra/Librar...3/default.aspx
Old 10-29-2018, 05:56 PM   #3
TClark
Default Intake manifold vacuum port
Here's a pic. Click image for larger version
Name:	Intake Manifold.jpg
Old 10-29-2018, 11:52 PM   #4
Bru
Bru's Avatar
OK, easy. That hose comes out and connects to a plastic T on the firewall. One side the T connects to a hard plastic hose that goes over to the heater control valve. I think there's a vacuum check valve there too. The other side connects to the cruise control and further on connects to the vacuum / pressure transducer that displays vacuum / pressure on the dashboard. There is another double T in that line between the cruise control and the transducer. See the photos and arrows. This is on a 1987 Turbo car. There may have been some changes between non-turbo and later years.
ID:	5023   Click image for larger version
Name:	Heater Valve.JPG
ID:	5024   Click image for larger version
Name:	Cruse and Turbo P.JPG
Old 10-30-2018, 01:00 PM   #5
TClark
Thanx, that's what I needed.
EGR Vacuum Modulator Wierdness Bru MKIII Supra 0 01-14-2015 10:57 PM
vacuum prob. plunkett81 Non-Generation Specific Questions 1 09-29-2012 12:53 AM
JDM vacuum lines. please help! Suprasexy MKIII Supra 2 01-04-2011 01:34 PM
AFPR vacuum hoses and an electrical problem Gunnar Non-Generation Specific Questions 0 06-11-2009 07:46 PM
Vacuum tube placement? atsomepoint Non-Generation Specific Questions 13 09-20-2007 02:02 PM
