Old 09-30-2019, 12:49 AM   #1
MK3MKB
MK3MKB is on a distinguished road
Default recently purchased '91
I recently picked up a '91 non-turbo manual car. The car was sitting for the last 10 years after the previous owner rebuilt the engine due to a rod knock and couldn't get the car to start again. So far I've jumped +B and FP and the fuel pump came on. I checked for power at the fuel pump relay with key on, didn't have power until jumped. The tach is jumping while cranking. I did get it to cough on brake cleaner to confirm spark.
Any pointers on where to go next would be great.
MK3MKB is offline   Reply With Quote
Old 10-05-2019, 09:41 PM   #2
MK3MKB
still working with this, I've checked the grounds on the intake. I've checked the EFI fuse. checked continuity across CPS. I doubt the alarm is the cause, I bought the car without a battery. Both sides of the injector plugs are hot at all times. I used a my test light while cranking to see if the light goes out on either side, it does not. I checked for any fluctuating using a multimeter, reads 0 volts while cranking with the probes on either side of the injector connector. One interesting note is the previous owner grounded the knock sensor wire.
Old 10-14-2019, 11:12 AM   #3
yale
yale is on a distinguished road
Have you confirmed the timing is correctly set? Sounds like you have spark and fuel, but maybe not at the right time.
yale is offline   Reply With Quote
Old 11-12-2019, 07:03 AM   #4
tmothy3
Check the wire from the battery going to the starter. Inspect also the engine ground.
New to Forum as of today..purchased 1986.5 Supra two days ago krash MKIII Supra 3 08-17-2011 02:28 PM
Just Purchased a 1982 Supra Ghettopoptart MKII Supra 1 01-16-2008 05:06 AM
Has anyone purchased tires from these sites? Chambers MKIII Supra 7 08-16-2007 03:27 AM
Purchased MAF on Ebay. Think I got scammed HaveBlue Non-Generation Specific Questions 2 10-15-2006 08:22 PM
Just purchased a 91 Supra, need help! Mr_Revesz MKIII Supra 5 03-07-2006 12:15 PM
