Old 10-03-2019, 03:38 AM   #1
Mk3 Mad
Mk3 Mad is on a distinguished road
Default Mk 3 Fuel Pump wiring issue
Hi All,
Have an issue with fuel pump not firing with key on. As per the manual and wiring diagrams I've checked all fuses, fuel pump relay, Circuit opening relay (removed and tested on +12V, cleaned contacts, triggers as it should). The pump itself seems fine, when I short the Fp and B+ terminals on the diagnosis link it fires and delivers fuel to the fuel rail. What it won't do is fire up and deliver fuel when cranking or with key to IGN. Without pulling the entire interior to inspect wiring, any thoughts? ECU? Something I haven't checked? Any genuine leads much appreciated, need this car running!!! Cheers
Mk3 Mad is offline   Reply With Quote
Tags
mk 3
Electrical signal not reaching fuel pump A.BuckShort MKIV Supra 7 03-21-2016 01:15 PM
Can I just buy a fuel pump filter? leftfoot MKIII Supra 8 08-11-2015 05:09 AM
91 1Jz fuel pump wiring turbophil MKIII Supra 1 04-17-2010 05:38 PM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
