Old 12-03-2019, 07:32 PM   #1
Fletch17
Fletch17 is on a distinguished road
Default Daily Driver?
I am a 16 year old kid and there seems like there is a good deal on a 89 supra with the 7m-gte with 93,000 miles. And obviously I'm not rich and I need something reliable. it needs a little work but nothing major. I just wanted to ask what you guys think.
Fletch17 is offline   Reply With Quote
Old 01-27-2020, 01:07 PM   #2
yale
yale is on a distinguished road
This response might be a bit later, but.....
Just 93K on it? Does it run?
There was a good post somewhere on this forum on things to check before buying that are specific to Supras. Can't remember them all but do a search for it. A few things I did before buying mine (86.5 with 127K four years ago).
Check the frame rails for rust. This is a uni-body so rust in the frame is going to be expensive to repair.
Open the storage panels left/right in the back and stick your hand down there to feel for moisture or rot. Leaking rear window will put a lot of water there and it has no where to go. My left side was filled with water!
Check the spare tire "pit". Great place to collect water and lots of rust.
While crawling around check the fuel tank for rust, particularly the right/left front corners behind the tires. Toyota in their infinite wisdom put a shield there to protect from rocks/debris but it also collects and holds dirt/moisture. Caused a lot of rust-through conditions in those spots.
Smoke out of the exhaust? If so, what color?
Normal checks like oil (color, smell), coolant (color, smell), under the oil fill cap (color, smell), heater work?, A/C work, etc......
Just a few ideas.....
yale is offline   Reply With Quote
7M-GTE 400 HP+ Daily Driver GHilts MKII Supra 1 05-23-2011 03:35 AM
1997 TT Supra Daily Driver Ember778 MKIV Supra 3 03-27-2010 10:54 PM
First supra, Daily driver Fixer upper Raysupra MKIII Supra 1 09-05-2009 03:52 PM
Turbo supra reliable daily driver? KhanArtisT MKIII Supra 7 01-08-2006 06:23 AM
