Piping for AfterMarket BOV?
I've been searching high and low for a solution to add a blow-off valve, and the only one I've found is the HKS BOV kit @ an average of $300. I was wondering where I might be able to find a cheaper solution?
here is the one i run. it rocks...
http://cgi.ebay.com/ebaymotors/Monza...spagenameZWDVW comes with flange adapter. :bouncy: |
Got pics? I've seen those kits too. Although, I was looking for a replacement pipe with a flange already installed, a true bolt on application that is reversable. Do you have pictures? I'm curious to see this installed.
bov pik
1 Attachment(s)
here it is monza ssqv, all the ones ive seen need to have a flange welded onto the intake. then the bov bolts or clips in to the flange? but i dunno what you mean by reversable?
Reversable, meaning that I can put it back into stock form without having to buy additional parts.
EDIT: Thanks for the pic. :) How much did you pay to have the flange welded? |
i have a wire feed welder and i did it myself.
yes. its a cheap 125 hobart mig but it works good. i saw harbor freight has a tig/arc for 300$ may get that.... I want to tig...
anyways.. ssqv bov's work better i think cuz the boost holds the valves closed un like the pull types BOV's that can leak under boost and can be slow to open and close. |
