Old 10-23-2005, 07:54 AM   #1
dcrusupra
dcrusupra's Avatar
Default Steering wheel shake
Hey all. I just replaced my rack and pinion. And now i have a metal on metal noise when i hit a slight bump. And almost like a ticking sound coming from the front end while im driving. I think its the ball joints. And if i go over about 45, the steering wheel starts to shake. So now im stumped. Anyone kno?
Thanks
Old 10-23-2005, 09:31 AM   #2
rnoswal
rnoswal's Avatar
Well if you put the rubber insolators back holding the rack, that part should be ok. The ball and socket ends of the rack must be tight, but enough to allow free movement. Could be upper and lower ball joint, then again it could be a wheel or tire way out of balance.
Also make sure the tie rod ends are on tight and that the wheel bearings don't have any real play in them. This doesn't sound like your problem, but if it is under braking, then the rotor could be warped.
Let us know.
Russ
Old 10-23-2005, 09:48 AM   #3
joel w
joel w's Avatar
usually the lower ball joints go out first.
Old 10-23-2005, 10:00 AM   #4
Moonraker
Moonraker's Avatar
Moonraker is on a distinguished road
Did you have it re-aligned?
Moonraker is offline   Reply With Quote
Old 10-23-2005, 03:45 PM   #5
joel w
joel w's Avatar
i dont think there is any adjustment at the ball joint itself, the adjustment is on the other end of the lower A arm, but if your old one was warn out, it will need to be re-alligned most likely.
Old 10-23-2005, 05:47 PM   #6
dcrusupra
dcrusupra's Avatar
Yea, after i got the rack and pinion put it they said they aligned it but it still pulls to the right a noticable amount. So you all think its the lower ball joint? I just put new brembo rotors on the front so its most likely not the rotors.
Old 10-24-2005, 06:39 AM   #7
Warped Rotors only give vibration when you are applying the brakes. If it is doing it just driving, then a bent wheel can cause it. This is a big problem with aluminum rims. Also...worn bushings are a big cause, even more than ball joints. Take it to the 'recommended best' front end shop in town and have them look at it. Most front end work is best done at the shop, as they will have the proper tools.
PS...if you had the rack put in at a front end shop, they should have checked everything out while it was there, and fixed it, because they are there to make $$$, and make YOU a happy customer.
Old 03-17-2006, 04:14 PM   #8
Isphius
Isphius's Avatar
My front wheel bearing is shot and that causes the car to shake when im going fast. I have a worn rear upper ball joint too, if anyone knows where to find these please let me know! and why are the wheel bearings 70$? i replaced them in a front wheel drive ford minivan and they were 9$ each.
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
Aftermarket steering wheel RTZ MKIII Supra 10 02-07-2008 08:44 AM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
What do i need for my steering wheel. paula Non-Generation Specific Questions 1 07-17-2006 01:03 PM
Steering wheel. lifesnotfair MKIII Supra 11 12-30-2005 12:26 AM
