Old 08-16-2021, 01:25 AM   #1
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
When the AC is engaged the computer bumps up the rpm's and when it shuts off it returns it back to idle. Try cleaning the idle speed control valve and be sure that the rubber check valve inside is pointing in the right direction on a GTE and not damaged. The motor is a stepper type which means it only moves slightly when each coil section is energized manually. There are 6 contacts. The order that they are energized determines the direction that the cone end moves to control the flow of air. Here is a link to the online supra manual for that testing.
http://cygnusx1.net/Supra/Library/TS...spx?S=FI&P=106
Rough idle on warm start up (20 minutes), 87 7MGTE Bru MKIII Supra 10 05-11-2012 12:27 AM
Rough idle and low RPMs at startup when cold... Fr0sTbY7eX MKIII Supra 7 01-27-2011 02:15 AM
87 N/A ...rough idle ochowdero MKIII Supra 2 09-09-2010 06:16 AM
Rough Idle Issue suprajim MKIII Supra 9 12-19-2009 10:35 PM
Rough Idle????? ZauggIt1 MKIII Supra 2 11-11-2006 08:50 PM
