Old 10-27-2005, 02:56 AM   #1
GreenChevelleSS
GreenChevelleSS's Avatar
GreenChevelleSS is on a distinguished road
Arrow Is my Turbo Leaking Oil ????
My engine had excessive carbon build up in the cylinders and I figured it was the rings so I was thinking of pulling the block and putting in new rings and checking the bearings and all, but today I pulled one of the intake tubes for the intercooler because it was messed up pretty bad what do I find oil pouring out of the intercooler and that tube so I started thinking that it is the turbo causeing all the carbon buildup instead of the rings. What do you think, I highly doubt the turbos ever been rebuilt but the engine is relativily new but who ever built it wasnt very smart. So what do you think should I go ahead and pull the rest of the engine, ive already got the head off, or should I put it back together and rebuild the turbo? Is there a way I can test the turbo for leakage?
1990 Toyota Supra Turbo 7M-GTE
1970 Chevrolet Chevelle SS 396
1996 Chevrolet Silverado Z71
www.cardomain.com/id/3115ultima
GreenChevelleSS is offline   Reply With Quote
Old 10-27-2005, 11:54 PM   #2
GreenChevelleSS
anyone have any ideas?
Old 10-28-2005, 02:26 AM   #3
joel w
joel w's Avatar
a little oil in the ic piping is normal (not pouring out) but a coating inside due to crank case venting back into the accordian hose before the turbo, Did it smoke when it was running last? describe it if it did.? when my turbo blew the oil seal, it was just a puff at first then next day it got worse as i let off on boost to an idle at speed it would smoke bad. bad enough i parked it for repairs. I havent heard of anyone actually having to install rings on these supras due to blowby, Not saying it dont happen but its not common that i know of? i guess it depends on your cash flow and what you plan is with the car, if your going for seroiuse power id pull it, but if your basically stock, i guess i would mic all the cyinders and look for sloppy pistons and if therewith in tolerences, slap it back together?? i got 157k on stock block and ive been at 10-14 psi for 2 yrs now woth no smoke issues ever..cept the turbo..
Old 10-28-2005, 02:55 AM   #4
GreenChevelleSS
well i got the car with a blown head gasket and I havent heard it run yet. I got it very cheap and figured I could fix it pretty cheap and fast and use for a daily driver instead of my consistent 15mpg truck.
When I pulled off the intake tube that goes in between the intercooler and the turbo, enough oil poured out to fill a about a 4oz container and then when I set that tube to the side more oil came out of it.
Old 10-28-2005, 03:08 AM   #5
Bullz_EyE
Bullz_EyE's Avatar
May I suggest a PCV Catch can breather?
Old 10-28-2005, 03:51 AM   #6
GreenChevelleSS
Yea i dont think this much oil could come from the pcv.
88 Turbo Leaking Valve Cover Gaskets Sheridan MKIII Supra 1 11-05-2007 01:03 AM
