Old 10-29-2005, 03:19 AM   #1
GreenChevelleSS
GreenChevelleSS's Avatar
GreenChevelleSS is on a distinguished road
Unhappy Removal of ENGINE and transmission
I'm about to remove the engine from my '90 supra the shop manual tells me to remove the transmission with the engine, but i dont want to, so can i just remove the engine and just leave the tranny in the car???
Thanks,
Dan
1990 Toyota Supra Turbo 7M-GTE
1970 Chevrolet Chevelle SS 396
1996 Chevrolet Silverado Z71
www.cardomain.com/id/3115ultima
GreenChevelleSS is offline   Reply With Quote
Old 10-29-2005, 03:51 AM   #2
Jrok25supra
Jrok25supra is on a distinguished road
Sure. I havent done it myself but i heard its easier that way.
Jrok25supra is offline   Reply With Quote
Old 10-29-2005, 04:32 AM   #3
lilsmitty
lilsmitty is on a distinguished road
Yea i just removed my engine with the tranny in the car. the ony hard thing to do is get the tranny bolts unbolted.
lilsmitty is offline   Reply With Quote
Old 10-29-2005, 07:34 AM   #4
mrnickleye
mrnickleye's Avatar
Coming out is fairly simple. Going back in is where the 'fun' begins. I've done both methods. I would pull trans/eng together, as you can put it all together, then slip it in.
Old 10-31-2005, 01:25 PM   #5
GreenChevelleSS
well engine is out..... Im so glad I did pull it, this is one nasty SOB, The rod bearings where really bad worn and the sludge and rust in the engine is horrible. We found another gasket leak and 3 pistons had rings so gummed up that they were stuck and its one PITA to get them out....
Old 10-31-2005, 02:12 PM   #6
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
Well, at least your making progress.
Bullz_EyE is offline   Reply With Quote
Old 11-02-2005, 04:10 AM   #7
mrnickleye
mrnickleye's Avatar
Smile
Well???? Did you pull engine and leave the trans??? Was it easy for you???
Old 11-02-2005, 08:00 PM   #8
rnoswal
rnoswal's Avatar
I have found that after getting at those damn bolts up high on engine/trans, that it is much easier to pull the engine separately. That is one heavy beast with both. You have to have a good hoist for that. The floor kind will almost flip up on you if you don't have it set up just right while trying to pull both. The overhead lift is best for pulling both, but if the trans doesn't need to come out then just pull the engine.
Russ
Old 02-10-2006, 06:10 PM   #9
tryin_hard
tryin_hard's Avatar
tryin_hard is on a distinguished road
Cool
i pulled the motorand tranny together and you're right..that is one heavy sob... the chain broke and the engine dropped into the engine bay...
88 turbo..... coming soon...twin turbo
tryin_hard is offline   Reply With Quote
engine removal mizuboi MKIII Supra 11 06-10-2011 06:25 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
