Old 10-29-2005, 03:52 AM   #1
Burn N' Up
Burn N' Up's Avatar
Lightbulb -Belt driven fan +Electric Fan(s)
Any comments? I'm wondering if the draw on the battery in a car that needs the power to produce a good sharp spark in a turbo charged (high compression) engine is gonna be a good idea. That and is the load to the alternator really that high. I've heard from two sources, one very reliable and one ont so reliable. The very source says they don't draw that much, the not so source says they do. Thoughts? Kits already out there? Thanks homies.
Old 10-29-2005, 07:48 AM   #2
No problem running electric fan(s). I run 3 on mine. 3 years now. On, get this now, the original 16 year old alternator. 162k on it.
Old 10-29-2005, 10:09 AM   #3
kewlcoconut
yea the alternators are really good in these cars. the stock one ran for 17 yrs then i replaced it. and then i fried the new one with my system haha. so i got the biggest i could get. 110 amp. thats as big as it would fit in the supra lol.
Old 11-01-2005, 10:08 PM   #4
Burn N' Up
Burn N' Up's Avatar
Mr Nickleye,
Where did you get your setup?
Old 11-02-2005, 03:07 AM   #5
Smile
Originally Posted by Burn N' Up
Mr Nickleye,
The car came with the factory setup, one fan w/clutch on water pump, and 2 little 6" electric one that come on with the a/c.
I removed the fan & clutch from water pump. I cut the fan shroud that was for that fan, leaving the portion for the little fans.
I mounted a Hayden 14" electric and used their temp sensor kit w/relay. I followed their directions for mount and hookup.
(next time I will use this one for more CFM... http://store.summitracing.com/defaul...=400006+306496)
I spliced into the 2 relays for the little fans, and ran a 'rocker' switch to operate them manually when I want (like around town in hot summer with a/c on all the time). I put the switch in place of one of the coin holders on the left side of dash.
If you don't have those little fans, then you should get one of those 2 fan setups. Check SummitRacing or JEGS.
I never run hot, and I live in the Mojave Desert, Ca. 110* summertime.
Old 11-02-2005, 08:04 PM   #6
rnoswal
rnoswal's Avatar
Get a 2 core aluminum radiator from summit or jegs, put a 16 inch fan on it and never worry again about overheating. I did and that is how mine ran in north louisiana, not hot!
Russ
Electric Fan? mkiiisupra MKIII Supra 24 06-18-2010 08:26 PM
Wiring Electric Fans mkiiisupra MKIII Supra 3 03-13-2009 04:58 PM
hydraulic fans oowee623 MKIII Supra 2 09-03-2007 05:22 AM
Electric fans fulljapan Non-Generation Specific Questions 4 08-14-2007 03:28 PM
Wanna install electric fan.... Supra89 MKIII Supra 7 10-07-2006 01:59 AM
