Old 10-29-2005, 08:21 PM   #1
lilsmitty
lilsmitty is on a distinguished road
Default Fuel injector wires...
Can anyone tell my the color of two little wire's going to the first fuel injector for the plug? I just put a new engine in my car and i want to make sure the injector plugs are on the right fuel injectors... Help me out..
lilsmitty is offline   Reply With Quote
Old 11-02-2005, 11:01 PM   #2
lilsmitty
Default ???
ANYONE Help?
Old 11-03-2005, 12:02 AM   #3
joel w
joel w's Avatar
looks like a white or tan wire with a blue stripe and a yellow wire for #1
Old 11-06-2005, 03:11 PM   #4
toyota_guru
toyota_guru's Avatar
toyota_guru is on a distinguished road
What year, and engine are you working on? Are you using the stock harness or the one for the new engine? Did you upgrade from a N/A to turbo? Need some more info to answer your ?.
Not even close to stock!
toyota_guru is offline   Reply With Quote
Old 11-07-2005, 09:44 PM   #5
lilsmitty
I put a stock engine back in it non turbo. 87 7m-ge
Old 11-09-2005, 04:24 AM   #6
lilsmitty
How bout the rest joel!!!! :-)
Old 11-09-2005, 04:27 AM   #7
joel w
joel w's Avatar
mines a 89 7mgte, but i will go look and edit this post for ya,
ok looks like they are as follows:
1 and 4 are yellow wire and blue wire w/ tan stripe
2 and 6 are red wire and white wire with black stripe
3 and 5 are solid tan and red wires
but that makes me wonder if mine are in the wrong spots? i would thunk that 2,5 and 3,6 were on the same like 1,4, but it sure runs good as is...
can anyone else confirm or confront these for me now hahhahahhaha
the coil packs run 1-6, 3-4, and 2-5 so im really confused now...
good luck...
Old 11-09-2005, 07:58 PM   #8
joel w
joel w's Avatar
Talking whew found it...
bammm. looks like mine are correct..if i read this scematic correctly...
http://groundsky.co.nz/techinfo/TSRM/25_D.pdf
good luck lilsmitty
Old 11-13-2005, 05:33 AM   #9
lilsmitty
your awsome bro... I just got done puttin my engine in and i tried startin it and it started for 5 sec.s and then shut off..... I had to buy a Vsv valve and a bvsv valve... Sucks ass cuz there like 300 bucks but i found some at a junkyard in cali but i will let you kno if she runs when i get the parts.... Hit me up on AIM sometime lilsmittyholla.... Peace
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
