Hi,
Ive recently installed a jdm non turbo engine and have encountered a problem. When the car is in Park, there are no problems red lining the engine but when the car is in drive or reverse the engine only gets upto about 1500 rpm's. Their is a miss upto about 1500 rpm, after that it smoothes out nice. Yesterday was the first time it had ever moved. Anybody have any ideas? Thanks very much |
wut do u mean by a miss up to 1500? sorry im kinda confused with your explanation as of now im thinking its something electrical
Now: Saving for an MKIV Broken Rides: (Sold) 91 supra turbo 5speed with a 1jzgte motor 421whp 400(399) ft*lbs of torque on tap @ 15 psi "Always outnumbered, never outgunned." |
Sorry...
While I am idling in "Park" their is a noticeable miss fire in the engine. When i begin to accelerate in "Park" the engine seems to be a little rough upto about 1500rpm, after 1500rpm i can continue to accelerate the engine and it will smoothly redline. I had to adjust the throttle linkage to idle smoothly.....(i thought the ECU automatically adjusted the idle speed). Whenever i put the car in "drive" and drove, it would not noticeably accelerate, the car had a max rpm of 1500. Im not really sure what this could be, ive compared this car to my other Supra when i install parts and everything seems to be good. This car did sit outside for 4 years and the engine had 275,XXX miles on it before i bought it and installed the N/A JDM Engine. Ive cleared the exhaust and have never swapped ECU's. Thanks for everyones help! Last edited by Wicked19; 11-07-2005 at 08:26 PM. |
hmm...it might be the ecu...i dunno when i swapped from a 7m to a 1jz...i had the 1jz ecu modified so it would read the speed in mph not kph, and i had it read the rpms differently...it might be the comp...sorry i cant help anymore..i dint have my 7m for that long so i did minimal stuff to it
problem seperating engine from manual tranny | Gengus | MKIII Supra | 7 | 01-29-2008 12:10 AM |
Engine Problem | 86toySupra | MKIII Supra | 3 | 04-17-2007 04:50 PM |
engine problem | nickalvrz | Non-Generation Specific Questions | 5 | 10-16-2006 02:51 AM |
Engine problem | malli | Non-Generation Specific Questions | 3 | 08-01-2006 12:44 AM |
engine problem... | sboy | MKIII Supra | 6 | 02-03-2006 01:09 AM |
