Old 11-07-2005, 11:59 PM   #1
boner1115
boner1115 is on a distinguished road
Default i may have blown my turbo?
my turbo started to only boost liek 4 psi, and it takes forever for it to spool. i am thinking my turbo is blown, how do i tell if it is, and if so what turbo should i buy to replace it.
boner1115 is offline   Reply With Quote
Old 11-08-2005, 12:40 AM   #2
joel w
joel w's Avatar
Default look for leak first.
just check your ic piping and couplers for a crack or leak , poped hose...b4 you buy new turbo.
pull your accordian hose off the intake of the turbo and inspect the blades for damage and the shaft for excessive play, ive heard if you can easily see it move, its worn out, but im not sure this is good info.. look for any metal scrapping or rubbing marks inside...
suppose there is other causes possably if the motor is not tuned properly or the exhaust is plugged but thats bout all i got.
Old 11-08-2005, 03:38 AM   #3
boner1115
it would boost to like 80 before jsut fine, but now it slowed down, and it will only boost to like 4 maybe 6 after a long ass time.
Old 11-08-2005, 02:45 PM   #4
SupraMan1784
i think you have a boost leak...gotta check connections from the turbo all teh way back....might have a leaky vacuum line
Now: Saving for an MKIV
Broken Rides:
Blown turbo? help a brother out sexy91tt MKIII Supra 0 02-09-2006 10:53 AM
