-   -   open end diff. sucks!! (http://www.toyota-supra.info/forums/mkiii-supra/2371-open-end-diff-sucks.html)
88Supraboy 11-08-2005 09:59 PM
ok , ive got an 88 N/A and to bad for me, its got an open end diff. and sometimes it really lets me down. i was wonduring how hard or even if posiable it would be to swap the diff. from a other supra with a limited slip or any others that would fit, or if i should just look into purchising an after market one.
thanks -Brian
Bullz_EyE 11-08-2005 10:29 PM
Don't quote me on this but I believe the rearends are swapable between the models. I've read the diff to look for is the LSD nonturbo model.
EDIT: This is what I gathered:
All differentials are straight bolt up affairs. Any year from any model can be swappable.
86.5-88: 3.9X
89-92: 3.7X
NA (sports package): 4.30
mrnickleye 11-09-2005 08:16 AM
^^ but the problem you may have is that the 'new' used LSD diff may be worn out. If it were me, I'd open it up and look into that used one, do a little testing on the bench, and probably rebuild it before installing it.
