Old 11-09-2005, 01:30 AM   #1
Isphius
Isphius's Avatar
Default 86.5 coolant leak
I have an 86 1/2 supra with an 88 motor that the previous owner swapped in...it was about 90% as bad as the original motor. anyway....there is coolant leaking from behind the head somewhere. i was reading about a water pipe back there somewhere.....but i was wondering if anyone else has had this problem. so far ive ruled out...broken heater core....hoses...and the head gasket. anyone have any advice?
Old 11-09-2005, 08:10 AM   #2
kewlcoconut
from behind the head somewhere? hmm... does it only leak when you drive it, then park? or can you see it leaking when you have the car running. i have had multiple coolant leaks. the biggest one i just had the other week was my heater core. you do not want that! expensive part to replace.
Old 11-09-2005, 08:12 AM   #3
Unhappy
You'll need a good flashlight and a mirror-on-a-stick to see it, let alone replace the hose. Good luck...
Old 11-09-2005, 09:41 PM   #4
Isphius
Isphius's Avatar
If i fill it, its fine. when it runs, it pumps it all out in about 20 mins. im replacing the whole motor anyway cause iy has a wicked rod knock, probably from the overheating problem (the last owner was pretty...idiotic). But this believs me to think its a pretty big leak....and its above the radiator somewhere and it has to be pressurized to come out. i already disconnected the heater core and it still leaks.
Old 11-10-2005, 07:54 PM   #5
toyota_guru
toyota_guru's Avatar
toyota_guru is on a distinguished road
There is a block off nipple on the back of the head that usually leaks, or it could be the egr cooler, both are culprits to leaking.
Not even close to stock!
toyota_guru is offline   Reply With Quote
Old 11-11-2005, 05:45 AM   #6
Isphius
Isphius's Avatar
Thanks for the help. The headgasket is blown anyway. it started smoking pretty bad today when i took it for a test drive, and it started running like a beotch. im guessing cause it was leaking oil all over the plugs. oh well im rebuilding a different motor for it anyway but i was hoping id be able to drive it while the new motor was underway....but i guess not.
Old 11-11-2005, 11:20 PM   #7
HD Supraman
HD Supraman is on a distinguished road
Unhappy 89 Coolant leak
On mine it was the by-pass hose between the back of the head and the firewall.
I've gone through three of them in the past year; time for braided steel, I guess.
HD Supraman is offline   Reply With Quote
Coolant Leak zcoolboard MKIII Supra 7 03-30-2009 06:54 PM
Strange Coolant Leak Help PLZ!! 87TurboProject MKIII Supra 11 03-14-2006 03:14 AM
MKIII coolant leak HELP sportriderseattle Non-Generation Specific Questions 2 12-21-2005 06:12 AM
