Old 11-12-2005, 08:02 AM   #1
shortman
shortman is on a distinguished road
Default Changing starter - 89 NA
This is my first post so be easy on me. Bought an 89 NA Supra - need to replace the starter. Bottom bolt easy - top one is hard to see - should I start peeling hardware off to get at it? Is there an easy way to do this one? Would love to hear from someone that has done this one before. I've done allot of starters on many vehicles - this one looks like it's not a favorite. This is such a real nice car - I almost felt guilty giving $400 for it. You have a great forum here. Thanks
shortman is offline   Reply With Quote
Old 11-12-2005, 08:24 AM   #2
You don't have to take stuff off to get it, just look carefully, and maybe with a mirror. You will have to use a swivel socket. The TSRM is silly.
http://www.cygnusx1.net/supra/librar.../st/ST_03.html
So perhaps someone can explain a more step-by-step, as I am going to bed.
Old 11-12-2005, 01:37 PM   #3
toyota_guru
toyota_guru's Avatar
toyota_guru is on a distinguished road
use a long extension with a swivel socket, feed the socket above the motor mount from the front, you have to do this by feel. Not one of toyotas better designs.
Not even close to stock!
toyota_guru is offline   Reply With Quote
Old 11-13-2005, 01:59 AM   #4
Burn N' Up
Burn N' Up's Avatar
I use the extension swivel trick with a box end on the other side to keep the nuts from moving.
Old 11-13-2005, 05:50 AM   #5
shortman
Default Thanks
Got it done - thanks for the info - you guys are great. Thanks again.
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
Starter Relay? Passenger Kick panel? dannydavi MKIII Supra 8 09-24-2007 01:12 AM
starter removel? swied MKIII Supra 4 04-23-2007 04:50 AM
