Old 11-13-2005, 03:12 PM   #1
j3pz
Default 7m vs 1jz
what are the pros and cons of the two engines and which one do you think is better over all
Old 11-13-2005, 03:27 PM   #2
toyota_guru
toyota_guru's Avatar
toyota_guru is on a distinguished road
I personally like the 7m, junkyard and aftermarket parts are more numerous and cheaper. you can make just about as much HP as you want with the 7m, same for the 1j, but, go to your local junkyard and see which ones are available and for how much. So if you break something, you can replace it quickly. Thats just my opinion.
Not even close to stock!
toyota_guru is offline   Reply With Quote
Old 11-13-2005, 11:05 PM   #3
the_fallen
the_fallen is on a distinguished road
similar power can be pulled from both engines, but the jz will take it for longer. the m series block has been around for 30? years now, so is getting a bit long in the tooth and should really be put out to pasture in my opinion. however toyota_guru is right in that the 7m's are cheaper and more readily available, so when you blow something, it would be easier to find a replacement.
the_fallen is offline   Reply With Quote
Old 12-07-2005, 04:56 AM   #4
Jebus
Jebus's Avatar
Jebus is on a distinguished road
Better overall engine, not taking into account price, i would say the 1jz. 7Ms are old, but simple maintenance is all it takes to keep them running, the internals are strong, its a 3 litre, it has a lot going for it... On second thought, i cant decide now which i like more.. lol What a waste of a post!
If only my Supra had a Novarossi!
Jebus is offline   Reply With Quote
Old 12-07-2005, 05:35 AM   #5
joel w
joel w's Avatar
mans got to know his limitations... mines cash... 7M all the way...
Old 12-07-2005, 01:03 PM   #6
lifesnotfair
lifesnotfair is on a distinguished road
Default Yeah...
I think I'll have to go with it too, because of that.
lifesnotfair is offline   Reply With Quote
Old 12-07-2005, 02:58 PM   #7
SupraMan1784
SP58GT
i think you know my answer....i got the big boy motor in my bad boy car hahaha, 1jz...but i aint hatin on the 7m...i had one before the hg blew, so mgiht as well swap motors right?
Now: Saving for an MKIV
Broken Rides:
Old 12-15-2005, 10:20 AM   #8
june bug
june bug is on a distinguished road
i haft to go with the 1jz because i own both.... but if you replace the headgasket on the 7m its not a bad choice but the 1jz can handle alot more power if you asked me.
june bug is offline   Reply With Quote
Old 12-15-2005, 02:19 PM   #9
kwnate
SP58GT
You can have a built 7m for the cost of a 1jz swap and still have no problems with emissions or inspections.
Nate
Old 03-25-2006, 06:35 PM   #10
Jazzsaxsupra
Jazzsaxsupra is on a distinguished road
I'm kinda personal to the 7M myself, but that's also because of my pitiful income... But if I won the lottery I'd get a 1JZ. :-)
Jazzsaxsupra is offline   Reply With Quote
