Old 11-18-2005, 09:39 PM   #1
boostedmkIII
boostedmkIII is on a distinguished road
Default Fuel Pump
Anybody out there know how much hp you can run before the stock fuel pump runs out of juice? My stock one is making noise and I have a nother stock pump, but if I knew how high I could run the stock one i could save a little on not having to buy a walbro untill I put the new turbo on this spring.
4" Turbo back/maft-pro powered/70mm TC turbo/JE Built forged motor
boostedmkIII is offline   Reply With Quote
Old 11-19-2005, 04:45 AM   #2
Reeves
Reeves is on a distinguished road
What does the noise its making sound like? When i step on the gas i hear a faint noise that I think may be the fuel pump. But yeah, not sure.
Reeves is offline   Reply With Quote
Old 11-20-2005, 04:16 PM   #3
boostedmkIII
Smile
The noise I hear is only when the ignition is in the on position with the car not running. The noise is like wah----wah---wah, something like that. No performance problems but its never made that noise before. The only reason I want to know how much power the pump will hold is that I have a extra one, and if I dont need a walbro for a while I dont need to spend money !!!!!!!!
Old 11-22-2005, 04:18 AM   #4
rays87turbo
rays87turbo is on a distinguished road
If you are still running the stock AFM, you don't need to worry about fuel. The AFM will limit you long before the stock fuel pump does.
rays87turbo is offline   Reply With Quote
Old 11-22-2005, 03:09 PM   #5
boostedmkIII
Thanks for info
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel pump hanger for 87 supra non turbo rlipp69 Non-Generation Specific Questions 0 06-16-2007 03:23 PM
Fuel Pump or what? Drack57 MKII Supra 7 11-28-2005 07:33 PM
