Old 11-22-2005, 02:27 AM   #1
sao1
sao1 is on a distinguished road
Default 1jz is not starting!
Hello,
Im such a newbie with supras. im sorry in advance to ask dumb questions. But two days ago my brother took out the car and drove the car just fine. When i went to start the car again, after about 4 hours, the car doesn't want to start.
The car would just crank and i would get not fuel and no spark!!!!!!!!
The fuel injectors is getting battery power and so are the coils, but still now spark and fuel.
I want to test out the fuel pump, but i don't know where it is on the car. And where is the igniter on the supra. Is there a crank sensor on the supra? And where? And which wire is the B+ for the automatic 1JZ ECU? So i can see if we are getting power to the ecu.
Sorry for all the questions, and thanks for looking.
sao1 is offline   Reply With Quote
Old 11-23-2005, 07:05 PM   #2
revolution
revolution's Avatar
revolution is on a distinguished road
fuel pump in the tank, mkIII has an access panel under the mat for the spare, 3 screws ur there. back probe it, while u key up with a test light. bad igniters r fairly comon on 7m, not sure about 1jz.(pricey items though). also about 3 relays r related to ur fuel pump. fi relay, main fi relay, pump relay, curcuit opening relay. my advice, if u couldnt find the fuel pump, take it to a shop
love my chev but it hates me
revolution is offline   Reply With Quote
Starting Problems turbo jim MKIII Supra 7 03-30-2009 07:09 PM
cold starting problems Cjanik MKIII Supra 9 08-02-2008 06:50 PM
starting motor Dom MKIV Supra 3 04-05-2007 01:57 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
