Old 11-15-2005, 04:29 AM   #1
87supraturbo
87supraturbo is on a distinguished road
Default Supra Trouble
Hey my 87 supra turbo is having lots of trouble starting, it will turn over for like 10 - 15 seconds then catch finally, studder then fire up and idle fine. But when you rev it to about 3 thousand and stay there while the car is standing still it will studder sort of. Its got brand new plugs and wires. Anyone have any ideas??, suprra_girl seems to know alottt.
Thanks,
Matt
87supraturbo is offline   Reply With Quote
Old 11-15-2005, 04:40 AM   #2
mrnickleye
mrnickleye's Avatar
Sounds like a fuel problem. You need to perform a fuel pressure and volume test. Then an injector test on all of them.
Old 11-15-2005, 05:54 AM   #3
ryemann32
ryemann32's Avatar
ryemann32 is on a distinguished road
Default i just put a new aftermarket fuel pressure reg in
i would start with what he said but i did some research on the pressure thing and it could very well be as simple as a vacuum leak with your reg it should atleast run bewteen 28 psi and 34psi i ve had to up my pressure but i do know at stock they run where i said i m running at 38 psi now wow what a big diffrence so after checking your pump i would move to the regulator next let me know if that is what it is if it is the reg i have one in good shape that i could sell u for cheap
ryemann32 is offline   Reply With Quote
Old 11-15-2005, 06:10 AM   #4
87supraturbo
Hey thanks for the suggestions, how do I go about doing a fuel pressure test, and volume test, and also testing the fuel pump, i know that i have to drop the fuel tank to get at the pump but after that I'm lost!!
Thanks,
Matt
Old 11-17-2005, 02:54 AM   #5
87supraturbo
Anybody, anybody at all?
Old 11-17-2005, 03:16 AM   #6
joel w
joel w's Avatar
http://groundsky.co.nz/techinfo/TSRM/
I think its under fuel injection section...
Old 11-17-2005, 08:19 PM   #7
Dejvid1785
Dejvid1785 is on a distinguished road
It could be timing! (Maybe)
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 11-19-2005, 12:47 PM   #8
rnoswal
rnoswal's Avatar
Just remember that each time you try starting the car, the cold start injector starts spraying. After a couple of times it will almost flood the engine. It will probably start but shake and stutter until it clears out the extra fuel. Make sure there are no vacuum leaks. Hoses get brittle along with gaskets. Spray some WD40 around those things when it is running to see if it changes the running. Most of the time it will rev up slightly and run a little better when you spray a leak.
Let us know
Russ
Old 11-22-2005, 12:18 AM   #9
87supraturbo
I'm pretty sure its not a leak, cause when i bought it, august, I had it inspected and I made a point of asking the guy to check for vacuum leaks.
Matt
Old 11-22-2005, 02:15 AM   #10
j3pz
Lightbulb not trying to be a butt
i took my car to get inspected and the people didnt pass it me and my dad did the work on to save $. so we did the list they gave us and took it back and they didnt pass it again and gave us a completely new list. we did all that and took it else where where it passed and they still missed an oil leak. all im trying to say is cant really trust the fellas. i know if i was them id slack off a little and maybe just skim over all the little tedious things
1987 toyota supra trouble starting derekrd Non-Generation Specific Questions 3 12-09-2008 05:05 PM
Supra fannatic but having crx trouble. stumpjumper Off Topic Forum 1 05-14-2006 05:10 PM
Trouble Shooting a 1989 Supra Turbo snowball MKIII Supra 62 01-02-2006 08:34 PM
