Old 11-23-2005, 11:10 AM   #1
kewlcoconut
kewlcoconut is on a distinguished road
Default light issue
my left headlight just started acting up tonight. i turn my lights on, and only the right light works. so initially i thought that it was the bulb in the light that was burnt out. which i thought was weird cuz they are new lights. so i put my lights to hi-beam. and low and behold, the light goes on when in hi-beam mode, but not low-beam mode. i checked everything i could think of. i havent replaced the bulb....but could something that simple resovle it??
to sum up:: left light does not work in low beam. works in hi beam for some reason.
kewlcoconut is offline   Reply With Quote
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
