Old 11-23-2005, 11:10 AM   #1
kewlcoconut
Default light issue
my left headlight just started acting up tonight. i turn my lights on, and only the right light works. so initially i thought that it was the bulb in the light that was burnt out. which i thought was weird cuz they are new lights. so i put my lights to hi-beam. and low and behold, the light goes on when in hi-beam mode, but not low-beam mode. i checked everything i could think of. i havent replaced the bulb....but could something that simple resovle it??
to sum up:: left light does not work in low beam. works in hi beam for some reason.
Old 11-24-2005, 12:26 AM   #2
It might be that simply. Get a test light and check the connector at the back of the bulb to see if you have power to the bulb. One wire is hi-beam, one is ground, the last is low-beam.
Old 11-24-2005, 12:31 AM   #3
joel w
joel w's Avatar
there are 2 elements inside the headlight,, one for hi and one for low.. sounds like just the low is toast?
Old 11-24-2005, 03:53 AM   #4
kewlcoconut
problem fixed. i took out the light and checked all the connection. there was a loose wire. probably the low beam one. works good now.
Old 11-24-2005, 04:22 AM   #5
Thumbs up
HEY !!!! That's what we like to hear (read) !!! Problems getting fixed, and quickly. And for free !!
Old 11-24-2005, 04:28 AM   #6
kewlcoconut
yea, im glad that i fixed it. its kind of embarassing in a way to drive around with one light hahaha. thanks for your help guys
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
