my left headlight just started acting up tonight. i turn my lights on, and only the right light works. so initially i thought that it was the bulb in the light that was burnt out. which i thought was weird cuz they are new lights. so i put my lights to hi-beam. and low and behold, the light goes on when in hi-beam mode, but not low-beam mode. i checked everything i could think of. i havent replaced the bulb....but could something that simple resovle it??
to sum up:: left light does not work in low beam. works in hi beam for some reason. |
It might be that simply. Get a test light and check the connector at the back of the bulb to see if you have power to the bulb. One wire is hi-beam, one is ground, the last is low-beam.
there are 2 elements inside the headlight,, one for hi and one for low.. sounds like just the low is toast?
problem fixed. i took out the light and checked all the connection. there was a loose wire. probably the low beam one. works good now.
HEY !!!! That's what we like to hear (read) !!! Problems getting fixed, and quickly. And for free !!
#6 |
yea, im glad that i fixed it. its kind of embarassing in a way to drive around with one light hahaha. thanks for your help guys
Check Engine Light & Warning light on | Chomper | MKIV FAQ | 19 | 02-11-2011 12:51 PM |
light on dash that tells you a light is out | D_Train | MKIII Supra | 7 | 08-04-2007 05:10 PM |
battery warning light / tail lamp failure warning light | MattJ | MKIII Supra | 5 | 02-06-2006 07:22 PM |
1998 Supra Check Engine Light | SupraLady | Non-Generation Specific Questions | 2 | 12-15-2004 11:39 PM |
