Old 12-14-2005, 11:06 PM   #21
snowball
snowball is on a distinguished road
OK here are the pics.
snowball is offline   Reply With Quote
Old 12-14-2005, 11:07 PM   #22
snowball
skyline44_2001 vbmenu_register("postmenu_3708866", true);
SupraForums Member
Trader Rating: (0)
make sure the cps is not 180 off, if it is it willbackfire and be very hard to start, sometimes u get lucky and it will start, but it will run like ass. also make sure the cams are right on. usually when it backfires it does mean u are getting spark and fuel, its just coming in and firing at the wrong time aka timing. double check and triple check it.
Old 12-14-2005, 11:08 PM   #23
snowball
shaeff vbmenu_register("postmenu_3708912", true);
*15psi bliss*
Trader Rating: (4)
Originally Posted by snowball
What do you think the next plan of attack should be....
clean everything FIRST! that'll make finding leaks and whatnot MUCH easier. start with your valve cover gaskets, hex head bolts, and new cove washers!
-shaeff
Old 12-14-2005, 11:09 PM   #24
snowball
snowball vbmenu_register("postmenu_3709073", true);
89 Turbo
Trader Rating: (1)
I was planning on putting the plugs for 5 and 6 back in. and then fill that little area with water. And then suck it back out. And repeat that over and over because I cant get like a rag down there or anything to clean it. Or does anyone else have a better idea? And should I try to get the gas out of the piston chambers.. or just don’t worry about it…
Old 12-14-2005, 11:09 PM   #25
snowball
alanflies vbmenu_register("postmenu_3709686", true);
SupraForums Member
Trader Rating: (0)
i used a shop vac with the long plastic tube extension. about 1.5 inces diameter. fits right thru the hole in the third cover and can suck all the stuff out of the cylinder bore and the valley at the same time. as for how the fuel got there... im not sure check everything for leaks, make sure the injector clips are on the right injectors. maybe you are flooding out on 5 and 6 because they are switched....in any case. and im serious here. make sure you take your time and find the problem with the fuel and definately clean all the fuel from the piston bore and the plug valley before you get cranking. it prolly wont crank with all that fuel in there anyway due to hydro lock. make sure the plug connectors are fully snapped onto the spark plugs. spark + fuel in the valley will surely burn your car to the ground.
Old 12-14-2005, 11:11 PM   #26
snowball
snowball vbmenu_register("postmenu_3710964", true);
89 Turbo
Trader Rating: (1)
OK, She is all vacuumed and cleaned out, I sucked up the gas that was in all the piston chambers. The only really bad ones where 1 and 6 I believe or 2 and 6 one of the front one and 6….
Old 12-14-2005, 11:11 PM   #27
snowball
shaeff vbmenu_register("postmenu_3711243", true);
*15psi bliss*
Trader Rating: (4)
now change your oil, because there's a good chance that gas seeped past your piston rings and thinned out your oil, thus reducing the lubrication, in turn increasing your chances of rodknock.
-shaeff
Old 12-14-2005, 11:12 PM   #28
snowball
snowball vbmenu_register("postmenu_3711486", true);
89 Turbo
http://supraforums.com/forum/image.p...ine=1132933386
Trader Rating: (1)
He Gave me a new oil filter also, Should I wait and run the new oil thought the old one and then after I get it running put the clean filter on?…. if you k now what I mean…
Old 12-14-2005, 11:12 PM   #29
snowball
87supedsupra vbmenu_register("postmenu_3711836", true);
SupraForums Member
Trader Rating: (3)
go ahead and change the filter as well, oil filters are like 5 bucks .
Old 12-14-2005, 11:13 PM   #30
snowball
snowball vbmenu_register("postmenu_3717617", true);
89 Turbo
Trader Rating: (1)
Ok, so today I had a friend and his dad come over to help me out on this thing. We took the valve covers off and noticed that both of the cam shafts where pointed inward. And we are not sure about the whole timing with the cam shaft. For the gears there are 3 Holes in the gear where we can the pin. But there are also 3 holes to which you can insert the pin in the block… So What hole does the pin go into on the gear and on the block? IM soooooo Confused… I guess what I am asking is. If I where to completely strip the block down and rebuild it. Can some one walk me through to get all the timing back and get everything synchronize where it is suppose to be. I looked through the Haynes manual and it was not very much help…. And looked through the http://www.cygnusx1.net/supra/libra...M/in/IN_01.html But that was not much help either…. I searched the forum and found nothing…. I need some assistance.
New to forum...1989 Bright Red Targa Turbo Supra Virgin, Pics included. whowouldfigga Show n Tell 3 03-13-2008 07:47 PM
