Old 12-14-2005, 11:14 PM   #31
snowball
snowball is on a distinguished road
shaeff vbmenu_register("postmenu_3719872", true);
*15psi bliss*
Trader Rating: (4)
both pins go in the middle holes.
here ya go:
set the crank notch to the 0* mark, as indicated on the timing cover. you'll see- 0*, 5*, 15* etc. allign it with the zero. then put the cam sprokets back on. the pin in the cams should go in the middle holes on BOTH sprockets.
place them so the notch marks in them are facing 12 0'clock. (alligned PERFECTLY with the notches in the black housing behind the cam sprockets)
now your motor is set to 0*. = base timing. put the timing belt on, without moving anything. once it's on, tighten the tensioner pulley a LITTLE BIT. now turn the motor over (**BY HAND**) 720*, and MAKE SURE that the cam notches are still alligned with the back plate notches, and that the crank pulley is still at 0*.
now tighten the tensioner pulley down the rest of the way. (i believe it's like 13-14ft lbs)
ok, almost done. now your base timing is set, and the car *SHOULD* start. once the car is started, and you've made sure there's no leaks or anything that could damage you or the car, turn it back off.
jump Te1 and E1 in the diagnostic block to put it into "timing mode" (which is really diagnostic mode), and loosen the bolt holding the cam position sensor (assuming you're turbo, if not then replace CAM POSITION sensor with DISTRIBUTOR). just crack it loose, not all the way!
now, start the car again, still in "timing mode" and get a timing gun hooked up. (one lead to the positive battery post, one to negative, and the inductor lead goes on the #6 spark plug wire because it's easier to get to.
point the light at the aformentioned numbers embossed on the timing cover ( 0*, 5*, 10* etc...) and turn the cam position sensor (or distributor if you're n/a) until the notch on the crank pulley appears to stay even on the 10* mark.
now your ignition timing is set. turn off the car, and tighten down the CPS or distributor bolt.
-shaeff
snowball is offline   Reply With Quote
Old 12-14-2005, 11:14 PM   #32
snowball
BFR1992T vbmenu_register("postmenu_3722149", true);
Moo
Trader Rating: (0)
and if the notches in the cam gears do not line up after tensioning the belt you may need to use the left or right holes in the cam gears and cams.
Old 12-14-2005, 11:15 PM   #33
snowball
snowball vbmenu_register("postmenu_3738520", true);
89 Turbo
Trader Rating: (1)
Ok, so today I got time to work on it. I took your advice and all those things where off. So I fixed that. I ran a cold, dry compression test and (from memory)
1=180, 2=176, 3=175, 4=176, 5=180, 6=183. And I tried to start it up and nothing… It like wants to start but.. it doesn’t. I know it is on the right stroke and everything I even tried the other, but like if I give it WOT then tried to start it and then stop and drop it to 25% gas it like goes put put put put. And it I don’t give it any gas or just leave it at WOT it just goes put, So……. IM stumped… I don’t know what to do know.. I checked to see if all the spark plugs are in the right order. I checked to c if they are getting spark. And it all checks out…
Old 12-14-2005, 11:15 PM   #34
snowball
shaeff vbmenu_register("postmenu_3738552", true);
*15psi bliss*
Trader Rating: (4)
i've never heard of them NOT lining up... he should be fine.
-shaeff
Old 12-14-2005, 11:16 PM   #35
snowball
shaeff vbmenu_register("postmenu_3738562", true);
*15psi bliss*
Trader Rating: (4)
are you getting fuel, air and spark?
if so:
then your timing is most likely still off. check the codes, and see what the CEL tells you.
-shaeff
Old 12-14-2005, 11:17 PM   #36
snowball
snowball vbmenu_register("postmenu_3738575", true);
89 Turbo
ya everything lines up..... (well not everything lol) something is wrong....
snowball vbmenu_register("postmenu_3738581", true);
89 Turbo
http://supraforums.com/forum/image.p...ine=1132933386
Ok, ya I have read so many post on check the codes and what not… but I never found something that explained the whole thing…
It is set at 0* and the cams line up….
Old 12-14-2005, 11:18 PM   #37
snowball
vbmenu_register("postmenu_3738622", true);
Newbie
Trader Rating: (0)
hey iv been readin your forume. im gunna sudgest a cupple things here. 1 you said that it has been sittin for a month see if its posible to find any water in your gas, 2 pull all the spark plugs out and then pull the coil plug out so that the plugs dont get any spark. then turn the engine over you probly have lots of water in there. make sure your plugs are nice cleen and dry, then put them back in
wow man look at your coil pack, the right coil pack is backwards, dude i think thats your problem it goes (left coil 1,6- center 3,4- right 5,2) if im seein it correctly you have cylinder 5,2 backwards try that and chek the coils for cracks i had to buy a new one for cylinder 1,6 it had a cupple cracks in it
im pritty sure thats your problem get back to me
harry
Old 12-14-2005, 11:18 PM   #38
snowball
harry89supra vbmenu_register("postmenu_3738654", true);
Newbie
Trader Rating: (0)
shit hahah my bad man, ya it is 16 34 25 its fine
but check for cracks on it u could have a dead coil
Old 12-14-2005, 11:19 PM   #39
snowball
snowball vbmenu_register("postmenu_3738998", true);
89 Turbo
Trader Rating: (1)
Yes, I had a quarter of gas in the tank and then I put lots more gas in and now I have more then half. So if there was any water in there. It should be diluted by now. But yet I have taken off the spark plugs and looked in there and I found some kind of liquid and sucked it put several times. And still no go….
Old 12-14-2005, 11:20 PM   #40
snowball
BFR1992T vbmenu_register("postmenu_3739023", true);
Moo
Trader Rating: (0)
-shaeff
Stretched timing belt or milled head/block deck will cause them to not line up.
New to forum...1989 Bright Red Targa Turbo Supra Virgin, Pics included. whowouldfigga Show n Tell 3 03-13-2008 07:47 PM
