Old 12-14-2005, 11:20 PM   #41
snowball
snowball is on a distinguished road
BFR1992T vbmenu_register("postmenu_3739024", true);
Moo
http://supraforums.com/forum/image.p...ine=1117678453
Trader Rating: (0)
Originally Posted by snowball
Ok, so today I got time to work on it. I took your advice and all those things where off. So I fixed that. I ran a cold, dry compression test and (from memory)
1=180, 2=176, 3=175, 4=176, 5=180, 6=183. And I tried to start it up and nothing… It like wants to start but.. it doesn’t. I know it is on the right stroke and everything I even tried the other, but like if I give it WOT then tried to start it and then stop and drop it to 25% gas it like goes put put put put. And it I don’t give it any gas or just leave it at WOT it just goes put, So……. IM stumped… I don’t know what to do know.. I checked to see if all the spark plugs are in the right order. I checked to c if they are getting spark. And it all checks out…
Have you checked the fuel pump and to see if you're getting fuel in the cylinders?
I mean, recently - after you cleaned out all of the fuel from before?
FYI most factory ECU's will cut fuel when the tps reads 100% (ie floored). This is a way to tell the ECU it's flooded and to stop injecting fuel while cranking.
snowball is offline   Reply With Quote
Old 12-14-2005, 11:21 PM   #42
snowball
snowball vbmenu_register("postmenu_3740388", true);
89 Turbo
http://supraforums.com/forum/image.p...ine=1132933386
Trader Rating: (1)
Aright I just did this http://www.cygnusx1.net/supra/techt...errorcodes.html and i got error code 14, and 51, but it has not been resent in a while so I reset it and tried to start it. and then I rechecked it and I am only getting error code 51….
Old 12-14-2005, 11:21 PM   #43
snowball
snowball vbmenu_register("postmenu_3740451", true);
89 Turbo
Trader Rating: (1)
I just went back out there and checked all the fuel injectors and they are all fringing ( I did the screw driver with the long handle and put my ear up to it and listen to a clicking sound)
Old 12-14-2005, 11:22 PM   #44
snowball
snowball vbmenu_register("postmenu_3740949", true);
89 Turbo
Trader Rating: (1)
Well, maybe I have bad fuel injectors…. Would they still click even tho there is no gas flowing through them… And I tried to take them out.. and I can not get the 3 bolts out.. that hold the bracket on. I searched but didn’t find anything on showing how to remove the fuel injectors but I might have missed. Ive read that they are Easy but.. the 3 screws that hold the rail on… I cant get a socket on them, and so I put a wrench on them. But I don’t want to strip the little suckers, I tried putting WD-40, Parts cleaning and all this other stuff… and nothing…
Old 12-14-2005, 11:22 PM   #45
snowball
BFR1992T vbmenu_register("postmenu_3741248", true);
Moo
Trader Rating: (0)
check the fuel pump first. put a paper clip between FP and +B in the check connector. Turn key to ON but do not start the car. You should hear the pump running and fluid flowing in the engine bay as fuel recirculates back to the tank.
You can check the fuel injectors by putting in dry plugs and cranking it over a few times - some of the plugs should become wet with fuel.
Old 12-14-2005, 11:23 PM   #46
snowball
snowball vbmenu_register("postmenu_3742022", true);
89 Turbo
Trader Rating: (1)
Aright I connected the FP (fuel pump) to the B+ (Battery positive terminal) yesterday and I forgot to tell you, But yes I could here it flowing. And The spark plugs come out wet. Sorry I should of told you that yesterday….
Edit: So, it is getting spark, gas and all the timing is correct, How do o check to c if it is getting air….
Old 12-14-2005, 11:24 PM   #47
snowball
harry89supra vbmenu_register("postmenu_3743773", true);
Newbie
Trader Rating: (0)
is your MAF sensor pluged in thing thats right behind the air filter
Old 12-14-2005, 11:24 PM   #48
snowball
harry89supra vbmenu_register("postmenu_3743781", true);
Newbie
Trader Rating: (0)
EFI fuse workin??????, chek every cylinder for spark im just throwin out ideas
Old 12-14-2005, 11:25 PM   #49
snowball
vbmenu_register("postmenu_3743880", true);
7M
http://supraforums.com/forum/image.p...ine=1132890208
Trader Rating: (
Its called an AFM, not MAF
Old 12-14-2005, 11:26 PM   #50
snowball
Yes, I am getting spark in all the cylinders like I already specified. All my fuses are good. And yes the AFM is plugged in : ) Today I took off my fuel rail and fuel injectors and cleaned them all. And still.. no gooo! WHAT ELSE COULD IT BE!!!
New to forum...1989 Bright Red Targa Turbo Supra Virgin, Pics included. whowouldfigga Show n Tell 3 03-13-2008 07:47 PM
