#51 |
TomBSupraT vbmenu_register("postmenu_3745996", true);
92 1jz s2 WideBody soon Join Date: Sep 2002 Location: Wilmington, MA Age: 20 Posts: 325 Trader Rating: (3) ![]() ![]() whats your fuel pressure look like? |
#52 |
snowball vbmenu_register("postmenu_3747453", true);
89 Turbo http://supraforums.com/forum/image.p...ine=1132933386 Join Date: Oct 2004 Location: Farmington hills, MI Age: 16 Posts: 70 Trader Rating: (1) ![]() ![]() ![]() Quote: Originally Posted by TomBSupraT whats your fuel pressure look like? How would I check that.. Its got a brand new 255 welbro fuel pump… but im not sure on the injectors.. and I tried calling a few places for the fuel presser test but no ones has it for my car… But I mean, It is still wet with gas when I take out the plugs…… I called like 4 dealers today and no one new…. They were all like oo man.. I don’t know that’s really wired.. |
#53 |
BFR1992T vbmenu_register("postmenu_3747657", true);
Moo http://supraforums.com/forum/image.p...ine=1117678453 Join Date: Feb 2002 Location: Ohio Posts: 207 Trader Rating: (0) ![]() ![]() Quote: Originally Posted by snowball How would I check that.. Its got a brand new 255 welbro fuel pump… but im not sure on the injectors.. and I tried calling a few places for the fuel presser test but no ones has it for my car… But I mean, It is still wet with gas when I take out the plugs…… I called like 4 dealers today and no one new…. They were all like oo man.. I don’t know that’s really wired.. Stock injectors? AFC? Might be flooding out, tho I'd expect it to atleast fire a few times and maybe idle a bit. You should cut off the j-tube restriction. |
#54 |
donavon vbmenu_register("postmenu_3747739", true);
SupraForums Member Join Date: Dec 2004 Location: va/md Posts: 12 Trader Rating: (1) ![]() Take the filter off and spray a little bit of carb cleaner in the intake. If it fires up for a second then the problem is fuel. If not then it may be spark or something else. |
#55 |
turboa7mgte vbmenu_register("postmenu_3747833", true);
www.sound-performance.com http://supraforums.com/forum/image.p...ine=1130236163 Join Date: Nov 2004 Location: Delavan, WI Age: 33 Posts: 897 Trader Rating: (6) ![]() ![]() ![]() ![]() this could be a bad conector, wire, or your timing is just off. Jiggle the CPS wires, make sure the conection to the coil packs is good.... and for the love of god.... check your grounds. and if all else fails.... sell the car to me. |
#56 |
snowball vbmenu_register("postmenu_3748131", true);
89 Turbo http://supraforums.com/forum/image.p...ine=1132933386 Join Date: Oct 2004 Location: Farmington hills, MI Age: 16 Posts: 70 Trader Rating: (1) ![]() ![]() ![]() Quote: Originally Posted by turboa7mgte this could be a bad conector, wire, or your timing is just off. Jiggle the CPS wires, make sure the conection to the coil packs is good.... and for the love of god.... check your grounds. and if all else fails.... sell the car to me. You should cut off the j-tube restriction…….(what is that (sorry) LOL NO, I would NEVER sale this car. The exterior is in PERFECT condition and so is the interior. And I got it for 2k from Wisconsin. Read Links for more info…… http://supraforums.com/forum/showthread.php?t=320803 http://www.cardomain.com/ride/2185313 |
#57 |
harry89supra vbmenu_register("postmenu_3748192", true);
Newbie Join Date: Oct 2005 Location: B.C. Age: 17 Posts: 49 Trader Rating: (0) ![]() fule filter pluged ![]() ![]() |
#58 |
(((((((((((((((((((((((((((((((((((((((((((( (((((((((((((((((((((((((((((((((((((((((((( (((((((((((((((((((((((((((((((((((((((((((( Ya that is only page 2 of the 4 pages on the other forum, SO when I get back form Christmas shopping I will update the rest. (((((((((((((((((((((((((((((((((((((((((((( (((((((((((((((((((((((((((((((((((((((((((( (((((((((((((((((((((((((((((((((((((((((((( (((((((((((((((((((((((((((((((((((((((((((( |
#59 |
i have the exact same problem and have tried everything he has said, sometime i can get it to start for a second but die ..im getting codes 14 and 51 every now and then... HELP
EDIT: I fixed it I bet this is your problem, take your coil packs off and clean them very good, all corrision gone. THen clean the plugs that plug into them! Hope this helps Last edited by kikwear002; 12-23-2005 at 06:24 AM. |
#60 |
Hey did you ever figure out your problem? I'm having the same issue. just finished rebuilding a 7M-GTE, brand new everything. finally got all the vac hoses coolant etc routed correctly. but i get turnover all day with no start. i do see/smell fuel in chambers and exhaust. i've checked all plugs, i DO get spark. tried numerous adjustments to CPS. after 3 hours of screwing around i finally got it to we're it'll put put. crank....... about 5 sec. put put. crank.... engine timing perfect. checked already. tried cleaning EVERY connector... especially coils with electrical cleaner. all connector snap in place and have good contact. tried disc/reconnecting cold start injector... no luck. help please
![]() Side Note: engine in car, no tranny mounted, but i connected the reveres and rear speed sensor JUST IN CASE for grounds ect.all ground straps connected, except i dont' know what the nipple on bottome of wrinkle hose (where stock BOV, MAF and turbo inlet hook up. so i plugged it. i had no other open vac/boost lines. everythign connected. tried gettign ecu to throw codes and i get nothing unless i press throttle IN car all the way down... then i get a TPS code.... also if i floor it. the TEMS( elec. suspension adjustent???) it's at 2 LEDs lit, but when pressed to near/at full throttle it shows a 3rd light. just wanna make sure its' normal. THanks for any help!!!. Los |
Thread Tools | |
Display Modes | |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
New to forum...1989 Bright Red Targa Turbo Supra Virgin, Pics included. | whowouldfigga | Show n Tell | 3 | 03-13-2008 07:47 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
