Old 12-14-2005, 11:26 PM   #51
snowball
snowball is on a distinguished road
TomBSupraT vbmenu_register("postmenu_3745996", true);
92 1jz s2 WideBody soon
Trader Rating: (3)
whats your fuel pressure look like?
snowball is offline   Reply With Quote
Old 12-14-2005, 11:27 PM   #52
snowball
snowball vbmenu_register("postmenu_3747453", true);
89 Turbo
http://supraforums.com/forum/image.p...ine=1132933386
Trader Rating: (1)
How would I check that.. Its got a brand new 255 welbro fuel pump… but im not sure on the injectors.. and I tried calling a few places for the fuel presser test but no ones has it for my car… But I mean, It is still wet with gas when I take out the plugs……
I called like 4 dealers today and no one new…. They were all like oo man.. I don’t know that’s really wired..
Old 12-14-2005, 11:28 PM   #53
snowball
BFR1992T vbmenu_register("postmenu_3747657", true);
Moo
http://supraforums.com/forum/image.p...ine=1117678453
Trader Rating: (0)
Stock injectors? AFC?
Might be flooding out, tho I'd expect it to atleast fire a few times and maybe idle a bit. You should cut off the j-tube restriction.
Old 12-14-2005, 11:28 PM   #54
snowball
donavon vbmenu_register("postmenu_3747739", true);
SupraForums Member
Trader Rating: (1)
Take the filter off and spray a little bit of carb cleaner in the intake. If it fires up for a second then the problem is fuel. If not then it may be spark or something else.
Old 12-14-2005, 11:29 PM   #55
snowball
turboa7mgte vbmenu_register("postmenu_3747833", true);
www.sound-performance.com
http://supraforums.com/forum/image.p...ine=1130236163
Trader Rating: (6)
this could be a bad conector, wire, or your timing is just off. Jiggle the CPS wires, make sure the conection to the coil packs is good.... and for the love of god.... check your grounds. and if all else fails.... sell the car to me.
Old 12-14-2005, 11:30 PM   #56
snowball
snowball vbmenu_register("postmenu_3748131", true);
89 Turbo
Trader Rating: (1)
You should cut off the j-tube restriction…….(what is that (sorry)
LOL NO, I would NEVER sale this car.
The exterior is in PERFECT condition and so is the interior. And I got it for 2k from Wisconsin. Read Links for more info……
http://supraforums.com/forum/showthread.php?t=320803
http://www.cardomain.com/ride/2185313
Old 12-14-2005, 11:30 PM   #57
snowball
harry89supra vbmenu_register("postmenu_3748192", true);
Newbie
Trader Rating: (0)
fule filter pluged ..... you say your gettin air fule and spark. are you able to do a pressure test on every cylinder. maby all your valves are messed up. if your not gettin good compression than your timein is off or valves are so ya yet again im thorowin out sudjestions
Old 12-14-2005, 11:31 PM   #58
snowball
Ya that is only page 2 of the 4 pages on the other forum, SO when I get back form Christmas shopping I will update the rest.
Old 12-23-2005, 04:39 AM   #59
kikwear002
kikwear002 is on a distinguished road
i have the exact same problem and have tried everything he has said, sometime i can get it to start for a second but die ..im getting codes 14 and 51 every now and then... HELP
EDIT: I fixed it I bet this is your problem, take your coil packs off and clean them very good, all corrision gone. THen clean the plugs that plug into them!
Hope this helps
kikwear002 is offline   Reply With Quote
Old 01-02-2006, 05:45 AM   #60
nat6c
nat6c is on a distinguished road
Hey did you ever figure out your problem? I'm having the same issue. just finished rebuilding a 7M-GTE, brand new everything. finally got all the vac hoses coolant etc routed correctly. but i get turnover all day with no start. i do see/smell fuel in chambers and exhaust. i've checked all plugs, i DO get spark. tried numerous adjustments to CPS. after 3 hours of screwing around i finally got it to we're it'll put put. crank....... about 5 sec. put put. crank.... engine timing perfect. checked already. tried cleaning EVERY connector... especially coils with electrical cleaner. all connector snap in place and have good contact. tried disc/reconnecting cold start injector... no luck. help please
Side Note: engine in car, no tranny mounted, but i connected the reveres and rear speed sensor JUST IN CASE for grounds ect.all ground straps connected,
except i dont' know what the nipple on bottome of wrinkle hose (where stock BOV, MAF and turbo inlet hook up. so i plugged it. i had no other open vac/boost lines. everythign connected. tried gettign ecu to throw codes and i get nothing unless i press throttle IN car all the way down... then i get a TPS code.... also if i floor it. the TEMS( elec. suspension adjustent???) it's at 2 LEDs lit, but when pressed to near/at full throttle it shows a 3rd light. just wanna make sure its' normal. THanks for any help!!!.
Los
nat6c is offline   Reply With Quote
New to forum...1989 Bright Red Targa Turbo Supra Virgin, Pics included. whowouldfigga Show n Tell 3 03-13-2008 07:47 PM
