#2 |
think about it this way it s not spinning with it s oil lines on so metal on metal don t spin it anymore till u prime it with oil. i just bought a new turbo and the instructions say to install it and then pull coil so no spark prime the inlet of turbo connect lines then turn over engine like u were trying to start it four or five times then pull the outlet line and see if oil is in line if so then reconnect and reconnect coil and start motor let idle for at least 20 min for breakin then u can take the car out for a spin but be very very carefull for at least 500 k before relly stomping on it alright i hope i could help u with your question
Window trim question | Isphius | MKIII Supra | 11 | 09-28-2021 05:52 PM |
Trim and moulding | carfanatic89 | MKIII Supra | 9 | 12-11-2010 04:30 PM |
ct26 upgraded to 60 trim.. Good or bad? | fexterz11 | Non-Generation Specific Questions | 5 | 03-20-2008 04:26 AM |
Rear Right Trim | D_Train | MKIII Supra | 3 | 07-14-2007 10:01 PM |
rebuilt and upgraged 50 trim.. | joel w | MKIII Supra | 0 | 10-23-2005 05:52 AM |
