Old 12-02-2005, 09:19 PM   #1
ShadowMKIII
ShadowMKIII is on a distinguished road
Question car lops like it has a big cam
My car lops realy bad and i cant figure out why i check for vacume leaks and checked the timing anyone have any ideas it started after i replaced fuel injectors and cleaned out throttle body
ShadowMKIII is offline   Reply With Quote
Old 12-03-2005, 12:22 AM   #2
mrnickleye
mrnickleye's Avatar
Pull plug wires one at a time to see which cyl. is mis-firing. Pull plugs and check. Sometimes after cleaning intake system, a plug or two will foul out.
Old 12-03-2005, 03:44 AM   #3
vladkalika
vladkalika is on a distinguished road
Check your timing.
That's what mine did 2 weeks ago after I did exhaust manifold gasket. The culprit was cam position sensor sitting one gear too far (distributor in 7MGE). Mine was 15-20 degrees advanced, barely idled.
vladkalika is offline   Reply With Quote
