Old 12-05-2005, 02:04 AM   #1
whitemk3
whitemk3 is on a distinguished road
Question ct 26 problems
i got a upgraded ct26 and when i spin it with my finger its very tight the turbo is pretty new. i bought it with an engine that had a blown rod. found lots of shavings in the oil pan. so im guessing it got into the oil line then into the turbo and scrued the bearing up. but i took it apart and noticed that when i loosing the nut on the compresser turbine it spins freely. i mean only hand tight that its spins freely but when i tighten it its almost impossible to spin. i clean the hell out of it but it still did it and i was told that since the car was sitting for a while that it needs oil to spin freely but thats hard to belive. so can someone please help cause a new one is preaty expensive unless i can fix or rebuild it thank and someone please help.
whitemk3 is offline   Reply With Quote
Old 12-05-2005, 02:49 AM   #2
joel w
joel w's Avatar
did you rebuild this your self or send it out to be rebuilt? if you sent it out, id call them..should be under warrenty if they did something wrong..
i did read your other post, oil will help...but there may be an issue inside. that doesnt sound good..? but i dont rebuild em..
Old 12-06-2005, 01:59 AM   #3
whitemk3
i got it wit the car so i dont no you rebuilt it its bugging me out
Want to buy a Supra, though having some problems finding one. Cypherbku MKIV Supra 3 03-03-2009 01:45 AM
problems problems problems.... 86SupraMan MKIII Supra 5 02-04-2008 04:28 PM
Starting problems and accleration problems! alekjame22 MKIII Supra 6 03-17-2007 11:19 PM
Oil leak problems adellicson MKIII Supra 1 03-04-2007 10:11 PM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
