Old 12-06-2005, 04:48 AM   #1
kewlcoconut
kewlcoconut is on a distinguished road
Default hatch
My hatch has the infamous squeak when I go over bumps and all. I know you can fix it by spraying some silicon somewhere. But my question is, where EXACTLY is the part that squeaks. I have spent time looking but I don't really know where its coming from. And lately it has been more frequent. Anyone know the exact area where the noise comes from?
kewlcoconut is offline   Reply With Quote
Old 12-06-2005, 05:44 AM   #2
1988gte
1988gte is on a distinguished road
I say the rubber stoppers, (looks like triangles on both sides of the hatch) glued mine back together till i get my replacements and my hatch dosent squeak like it did before
1988gte is offline   Reply With Quote
Old 12-06-2005, 06:48 AM   #3
kewlcoconut
hmmmm ok. i will take a look at my stoppers tomorrow and see if they need to be fixed. thanks
Old 12-07-2005, 06:31 AM   #4
mrnickleye
mrnickleye's Avatar
Thumbs up
And the 1/2" round ones along the back, on each side of the latch, out towards the ends. I used to spray silicone, but now I dab a tiny smear of clear silicone grease. Its like vaseline, but not as 'wet'.
Also if you look closely, you'll see some 'rub' spots up along the top, where the wiring harness and washer hose rub the channel in the body. Put some there too.
Make sure your latch is adjusted so the hatch is tight when closed.
Hood & Hatch Supports mrnickleye MKIII FAQ 2 04-16-2009 01:37 PM
Rear Hatch Won't Open-HELP! Benesesso MKIII Supra 4 07-21-2008 12:37 PM
Hatch Problems AZN_Pride MKIII Supra 6 07-27-2006 03:56 AM
