Old 12-06-2005, 10:24 AM   #1
WilliamBodie
WilliamBodie is on a distinguished road
Default Standard /static Timing setting
G'day guys,
Just put my motor back together and fired it up today, trouble with the timing i didn't know the standard settings so I set everything to Zero, What is the factory setting for the static timing, also a few of the small air hoses under the intake manifold need re attaching where do they connect??
Thanks for your help
WilliamBodie is offline   Reply With Quote
Old 12-07-2005, 06:35 AM   #2
Thumbs up
10* base timing
try this (and next page too) for vacuum lines.
http://www.cygnusx1.net/supra/librar.../ec/EC_03.html
Old 12-07-2005, 06:49 AM   #3
skunk
skunk's Avatar
also when you disassembled your motor, if you didnt mark your cam positioning sensor and now your having a hard time hitting 10 degrees you could be 180 out...you will know if you can only get the timing light to go to 5 or 15...it does happen, and make shure your cam timing is on
Old 12-07-2005, 12:14 PM   #4
WilliamBodie
Default Cheers Guys
Thanx for your help and advice guys, that is just what I was after. I marked all the hoses and pipes with paint when I disassembled the motor, and then gave everything a good clean "Der" then when I started to put it all back together "oops" of course all my marking were gone, just goes to show the best laid plans can still turn to crap
Old 12-07-2005, 12:18 PM   #5
WilliamBodie
Default 10 degrees base ??
Hi Mrnickleye,
so when you say ten degrees base, I set my Crank to 10 then line my cams up to the mark and find a tooth ??
I set my crank to 0 and lined my cams up so I would be a tooth out on the belt !!
is that what you are saying or am I misunderstanding you
Ps Thanxs for the link, thats champion
Old 12-08-2005, 04:03 AM   #6
Thumbs up
I thought you meant the dis/cam sensor timing (with the timing light).
When you set up the belt timing with the cams and crank, all the marks are on '0'.
http://www.cygnusx1.net/supra/librar.../em/EM_29.html
Old 12-08-2005, 11:35 AM   #7
WilliamBodie
Default Yep thats wot I thought
Thanx Mr nickleye thats what I thought it should be I found out today that Base timing is timing with the short in the diag plug all good !!!
cheers,
Will
Distritbutors Setting hangsupra MKIII Supra 1 08-11-2008 05:54 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
setting timing on a GTE djalkyd MKIII Supra 0 03-19-2006 04:39 AM
Setting the timing?? Dejvid1785 MKIII Supra 0 02-16-2006 04:12 AM
