Old 12-07-2005, 10:21 AM   #1
Jebus
Jebus's Avatar
Jebus is on a distinguished road
Default Lazy eye
I know it been covered before somewhere, but i just cant find it, maybe not this forum, but anyway, i need a link to how to set up your headlights for the lazy eye look? Saw one in real life the other day and does look really good on the Mkiii. Thanks
If only my Supra had a Novarossi!
Jebus is offline   Reply With Quote
Old 12-07-2005, 02:56 PM   #2
SupraMan1784
SP58GT
theres a thread on here under the exterior, interior, and detailing heading about the sleepy eye..its like the 4 or 5th post down
Now: Saving for an MKIV
Broken Rides:
Old 12-09-2005, 05:27 AM   #3
Jebus
Jebus's Avatar
Thanks Supraman. I'll check it out. All i really need to know is in some cases of adjusting the motors i have read people disconnecting something once they are set? And some dont mention anything about disconnecting anything? And once they are set, do the lights still pop up to full when you put your lights on? Anyway, thanks again.
Old 12-09-2005, 07:22 AM   #4
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
Highly recommend getting the Pivot pop-up headlight adjuster from Ebay or something. It allows you to adjust the headlights to close at any height via a rheostat. By using this you can have your sleepy eye set up and when you need your headlights turned on they will close fully and open up fully then return to sleepy mode after you turn them off. You're looking around 70 bucks for this thingy, but it has full instructions and it's really easy to install.
Drag0na5h is offline   Reply With Quote
Old 12-10-2005, 05:04 AM   #5
Jebus
Jebus's Avatar
Thanks Dragon. Sounds like the way to go. Does this mean that they dont move if you set them without the kit using the motors?
Old 12-10-2005, 06:35 AM   #6
joel w
joel w's Avatar
or you can just turn em on and off real fast and catch them half way...
(some skill required)
lazy look flip lights miisterMK3 MKIII Supra 3 09-08-2005 08:39 PM
