Old 12-07-2005, 10:21 AM   #1
Jebus
Jebus's Avatar
Jebus is on a distinguished road
Default Lazy eye
I know it been covered before somewhere, but i just cant find it, maybe not this forum, but anyway, i need a link to how to set up your headlights for the lazy eye look? Saw one in real life the other day and does look really good on the Mkiii. Thanks
If only my Supra had a Novarossi!
Jebus is offline   Reply With Quote
Old 12-07-2005, 02:56 PM   #2
SupraMan1784
theres a thread on here under the exterior, interior, and detailing heading about the sleepy eye..its like the 4 or 5th post down
Now: Saving for an MKIV
Broken Rides:
Old 12-09-2005, 05:27 AM   #3
Jebus
Jebus's Avatar
Thanks Supraman. I'll check it out. All i really need to know is in some cases of adjusting the motors i have read people disconnecting something once they are set? And some dont mention anything about disconnecting anything? And once they are set, do the lights still pop up to full when you put your lights on? Anyway, thanks again.
Old 12-09-2005, 07:22 AM   #4
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
Highly recommend getting the Pivot pop-up headlight adjuster from Ebay or something. It allows you to adjust the headlights to close at any height via a rheostat. By using this you can have your sleepy eye set up and when you need your headlights turned on they will close fully and open up fully then return to sleepy mode after you turn them off. You're looking around 70 bucks for this thingy, but it has full instructions and it's really easy to install.
Drag0na5h is offline   Reply With Quote
Old 12-10-2005, 05:04 AM   #5
Jebus
Jebus's Avatar
Thanks Dragon. Sounds like the way to go. Does this mean that they dont move if you set them without the kit using the motors?
Old 12-10-2005, 06:35 AM   #6
joel w
joel w's Avatar
or you can just turn em on and off real fast and catch them half way...
(some skill required)
Old 12-11-2005, 04:38 AM   #7
kwnate
Sleepy eyes suck. Just my opinion...
Nate
Old 12-11-2005, 05:20 AM   #8
joel w
joel w's Avatar
^^ i agree, It makes the car look like it should be drug tested..
Old 12-11-2005, 06:55 AM   #9
Jebus
Jebus's Avatar
Thanks Nate for your input, helps me a lot. Is'nt there a section for tool bags full of useless comments?? Im sure someone will get something out of your dribble but maybe here is just not the ideal place for your special kind of help. Thanks again.
Old 12-11-2005, 05:10 PM   #10
kwnate
Well excuse me, sounds like you've already got your answer... Go to ebay and get Pivot pop-up headlight adjusters. While your on ebay you can pick up some streetglow and maybe some vynal graphics!! That will really set it off!!
Nate
lazy look flip lights miisterMK3 MKIII Supra 3 09-08-2005 08:39 PM
