Old 12-08-2005, 03:12 AM   #1
ryemann32
ryemann32's Avatar
ryemann32 is on a distinguished road
Default does anyone know anything about external wastegates
i ve just recieved my external wastegate and have a question the top side has 2 release vale opennigs 1 on the top and 1 on the side on the backside of the diaphram could someone familiarize me with how these to work together since i will be the one setting this up and am confused on which one does what thanx if u could
ryemann32 is offline   Reply With Quote
Old 12-10-2005, 03:59 PM   #2
joel w
joel w's Avatar
see your other thread, but i will ad that it will work just fine using just the one port if you dont have regulator installed.. your boost level will be dependant on what spring is installed in the waistgate.
Old 12-11-2005, 08:20 AM   #3
ryemann32
ryemann32's Avatar
Default thanx for the info
so what u are saying is without a regulator i m fine but i did buy a manual boost controller to does this work with this setup to
Old 12-11-2005, 04:20 PM   #4
joel w
joel w's Avatar
yes it should be fine.. if its a bleeder type MBC then it should go inline on the first port, and nothing on the second port...
Old 12-11-2005, 06:41 PM   #5
ryemann32
ryemann32's Avatar
Default the one i bought
i bought a dual action manual boost it has a coarse adjustment aswell as a fine adjustment the guy said it is the best one out there
External Wastegate! teedoff00 MKIII Supra 1 04-11-2007 03:49 AM
External wategates 1988gte MKIII Supra 0 11-18-2006 08:26 PM
