#15 |
Personally, I'd just bolt the tranny back on, drain the tranny, pull the driveshaft, disconnect all the wiring/clutch/speedometer stuff, and pull the tranny with the engine... that's what I did when I blew the engine in my supra and had to replace it. If you pull the tranny, beware that you take care of the back-up light switch connector, because they're hard to find if you break them.
Tranny ? Need Info! | SilverBullet05 | Non-Generation Specific Questions | 0 | 07-07-2008 09:45 PM |
Auto Tranny Issues? | jbjorndal | MKIII Supra | 3 | 03-14-2008 09:31 AM |
problem seperating engine from manual tranny | Gengus | MKIII Supra | 7 | 01-29-2008 12:10 AM |
clutch slip | skunk | MKIII Supra | 11 | 11-29-2005 08:33 PM |
