Old 11-12-2005, 08:53 PM   #1
poodlepower
poodlepower is on a distinguished road
Angry can't start my 87 turbo!!
Okay, this is offically driving my crazy. My car won't start. It cranks but as if the spark or somthing is being disallowed electronically, preventing the engine from firing up.
It all started when my brake light switch went bust and killed the battery. i replaced the switch and battery and now the car won't start. I've read all the threads about the security system and tried the driver side and passenger side locks to disarm it. I also tried the turn twice to the right from lock position and still nothing. Any other tricks would help greatly!!
poodlepower is offline   Reply With Quote
Old 11-12-2005, 09:05 PM   #2
joel w
joel w's Avatar
whenever i disconect the battery, i always have to turn the key to the run position before i connect the battery back up. its the only way to keep the alarm from tripping and killing my starter. worth a try...
Old 11-13-2005, 07:05 AM   #3
poodlepower
Default gave it a try...
thanks... worth a shot but still no go
Old 11-13-2005, 02:17 PM   #4
ddmcse
ddmcse's Avatar
Cool
is it getting spark or not ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 11-14-2005, 03:59 AM   #5
Jazzsaxsupra
Jazzsaxsupra is on a distinguished road
the security system in the supra is a major pain... i spent an hour trying to get it to start one day, only to find the system had tripped. I got it working by getting out and locking it by the driver's side door, then unlocking it and giving it another go. Worked for me, maybe it'll work for you...
Jazzsaxsupra is offline   Reply With Quote
Old 11-15-2005, 02:31 PM   #6
poodlepower
Thumbs down been there, tried that...
tried the door lock on both sides... and i'm getting a spark. also my ignitor works and i checked all the wiring (that i could get at). she's been sitting there for over a month now and i need it out before it snows... this is crazy!
Old 11-15-2005, 04:15 PM   #7
joel w
joel w's Avatar
is the starter engaging? if not, tap your starter with a hammer while some one cranks it over. may just be bad starter? but it must be cranking if you got spark? hmmmm perplexed...
Old 11-19-2005, 02:18 AM   #8
poodlepower
well, it's off to the dealer. i'm getting her towed tomorrow to get the japanese toyota techs to figure this one out... guy on the phone said it's most definately electrical; could be feul pump or any number of things apparently. more on this as it develops!
Old 11-19-2005, 12:40 PM   #9
rnoswal
rnoswal's Avatar
Well there is that fuel pump relay thing in the fuse box under the hood, but it doesn't matter since it is probably at the most expensive repair shop in the world. Hope they don't find you need a new driver seat or anything.
Let us know what they found. It is fun guessing on here, but we don't always get to hear if any of us were close or not.
Russ
Old 11-22-2005, 01:12 AM   #10
poodlepower
noone would have guessed this one i don't think... cam position sensor is bust. unfortunately it's part of a massive distributor assembly that will have to completely be replaced (this is what i've been told). if anyone had this problem and knows how to repair the sensor without a massive overhaul of the distributor that would be great... because a new assembly is like $850!!
My Supra Turbo will not start GMKC1234 MKIII Supra 4 08-25-2006 10:06 PM
