Old 12-17-2005, 07:07 PM   #1
*c-town*
*c-town*'s Avatar
*c-town* is on a distinguished road
Default stripped spark plug
Hi new to the forums my cuz has a 86.5 supra n/a with a jdm swap and it has a stripped spark plug hole (no threads on head) my question is should he have the head heilcoiled or get a new (to him) head? Also is this common?
*c-town* is offline   Reply With Quote
Old 12-17-2005, 09:08 PM   #2
mrnickleye
mrnickleye's Avatar
It likely can be helicoiled. When I was at the dealer, I used a threaded metal insert called 'keensert'. They work better than helicoil, as they won't ever come out with the spark plug. I've gone to do a tune up on a car that had been helicoiled, and the coil came out with the plug.
There are other better helicoils now, that are not supposed to come out. There was a thread on them here, or on supramania forums.
Old 12-19-2005, 01:18 AM   #3
*c-town*
*c-town*'s Avatar
Thanks i think we'll remove the head soon and do a helicoil or can you tell me more about the "keensert"
87 Acura Legend Coupe LS 5-speed
88 Acura Legend Sedan L 5-speed
95 Jeep Grand Cherokee Limited 4x4
Want Supra MKIII Turbo 5-speed
Old 12-20-2005, 03:27 AM   #4
mrnickleye
mrnickleye's Avatar
I never removed the heads. Did it right on the car. Bring the piston all the way up to the top on that hole. Do your helicoil thing, then vacuum the cylinder out with a strong shop vac and a clear plastic hose (home depot, lowe's, etc) that is small enough to go down the hole and rotate around.
Helicoil site... http://www.emhart.com/products/helicoil.html
keensert...... http://www.keensert.com/
threaded inserts... http://www.carrlane.com/catalog/inde...1E173C1B08535A
Tool trucks, like Snapon, Matco, Mac, will have what you need also.
They will sell to the public for cash. Check phone book, or ask you nearest shop for their #.
Spark plug wires Quik Q carfanatic89 MKIII Supra 2 05-22-2008 01:46 PM
Broken spark plug! HELP! supraman121 MKIII Supra 2 10-02-2006 08:40 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
spark plug wires kewlcoconut MKIII Supra 2 03-19-2006 07:45 AM
Spark plug leads for 1g ekoston69 MKIII Supra 0 12-30-2005 03:18 AM
