Hey I figured i'd go ahead and start collecting names. Once we have 20 we all pay in, probably with paypal, and i'll place the order... that is if you trust me >=D lol. In the event that i'm not allowed to start a group buy perhaps Supra Girl will pick it up?
Guesstimated price was 100$ give or take plus what seems to be 6$ or so says Joel. The idea is that you distance the intake manifold and throttle body from the head to prevent the heat of engine operation from transferring to the incoming air. You replace your head to intake manifold and manifold to throttle body gaskets with these spacers and gaskets. Averages sound around 6-8hp for smaller engines than the 7M. We should be rippin. http://www.toyota-supra.info/forums...read.php?t=2039 So far it looks like: 1.Jrok25Supra 2.Joel Williams 3.Prez 420 4.Supra 91 5. Burn N' Up 6. Strannik 7. Reserved for non-forum member by Burn N' Up 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. Any other Takers? P.S. Email these guys and let them know you want to cast your vote for a 7M series spacer. Hopefully we can take advantage of the rest of the worlds interest in our engines. tech@outlawengineering.com Last edited by Burn N' Up; 01-02-2006 at 02:05 AM. |
im gonne do the 2jz intake thing so i dont need it
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
I might be intrersted, but whats this intake spacer? more HP?
here is the original thread..
http://www.toyota-supra.info/forums/...ead.php?t=2039 |
even if you do a 2jz style FFIM, it uses the same configuration runners as far as mating to the head right?
#6 |
that is true, didnt think of that. next excuse is... i need an engine first...
intake manifold | dumbass | MKIII Supra | 6 | 02-28-2008 02:42 PM |
5mge intake manifold upgrade | Allen Crump | Non-Generation Specific Questions | 1 | 11-02-2006 01:53 AM |
intake manifold has coolant what did i do wrong? | 91toy supra | MKIII Supra | 6 | 09-16-2006 02:46 PM |
custom intake manifold | j3pz | MKIII Supra | 8 | 12-07-2005 06:23 PM |
