Old 12-19-2005, 10:46 PM   #1
Toyota drive
Toyota drive is on a distinguished road
Exclamation HELP! 1987 Turbo
I just baught 87 turbo, 5 speed Supra that has some minor problems. The first night i had her, the factory alarm went off. So i got in and turned the key and it shut off. Then when i went to start it, it didnt do any thing. So after a while of trying to figure out what to do, a friend and i bump started it. She ran fine after that, but i still had to bump start after shutting it off. So i went to a friends house and disconected the negitive battery cable for a few minuits, put it back on and she started right up. It ran good the rest of the night. The next night, i was driving down the road and went to make a turn, so i pushed in the clutch and it started to sputter. I stoped and it started to run really rough and then died. I tried to start it again and the starter did nothing. All of my accessories worked but not well at all. So after a bit of playing around i replaced the battery and she started right up. I drove it for a day and now she started to run choppy again, and it shut off. It wouldent start again after that. I hooked up a battery charger and she started fine, but only ran good for a few minuits, until she finally died again. Im guessing that i have a bad alternator. But also i have a fuseable link where the alternator fuse is in the fuse block under the hood. Im really hoping for some suggestions and also i need to know how to disconnect the factory alarm system. Thank you very much, Danny.
Toyota drive is offline   Reply With Quote
Old 12-19-2005, 10:50 PM   #2
joel w
joel w's Avatar
after the alarm goes off, the alarm needs to be reset by locking and unlocking the door before the starter will function...
Old 12-19-2005, 10:54 PM   #3
Toyota drive
I read that in the manual, and tried it in the parking lot after the alarm went off. But it still wouldent start.
Old 12-19-2005, 11:25 PM   #4
joel w
joel w's Avatar
try the other door also, just for fun, but sounds like a bad altinator. not sure about a fusable link.. just check all fuses with a test light..
Old 12-19-2005, 11:58 PM   #5
Toyota drive
I dont think im really having a problem with the alarm. The only reason i mentioned it is because i had heard that they could cause battery drain, and if that may be a problem, Id rather just disconnect it. Also my cam position sensor doesent have a cover on it. I dont think there is any problems, but obviously i want to get a cover on it. Would you recomment just getting the cover or getting a new one?
Old 12-20-2005, 12:14 AM   #6
joel w
joel w's Avatar
yeah me too... , i skimmed your first post too fast, my bad.., on the CPS, if its working fine,, just get a cover, good luck..
Old 12-20-2005, 12:59 AM   #7
Toyota drive
OK. Thanks a lot for your help man!
Old 01-05-2006, 09:50 AM   #8
Isphius
Isphius's Avatar
the alarm is very easy to disable. and ill have to agree sounds like either your alternator is bad, or you have a small short somewhere which can cause both things you described to happen. ive heard the back of the fuse block corrodes, and other things like that. I disabled my factory alarm in about 25 mins once i learned how. Just have to be very agile to reach it good. All you really have to d ois unpulg it thou, not take the computer out. and then you have to re attach the starter ground cable to the body, which will need a wire extension. goodluck with the car tho!
About to be handed down a 1987 Supra Turbo. Need help/Advice on restoration. j0ker MKIII Supra 2 08-09-2008 06:42 PM
